Question about Kenmore 62109 Microwave Oven
Can't figure how to change settings from high to low
I have a Kenmore counter top 66469
  • Kenmore Master
  • 9,042 Answers
If you've lost your owner's manual, you can often find them for free download at the Sears parts site.
Just enter your model number and on the resulting page, look for a manual button on the right side of the screen.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Posted on Nov 21, 2008
Is it possible to check the magnetron
The magnetron looks like the below image
testing is not easy as it's a high voltage component and can be dangerous to work around.
Here is a link for a page with some very helpful information about testing magnetrons.
LINK:
Mar 07, 2012 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore microwave 665-68601890 runs but does not get food hot
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 25, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
My microwave just stopped working. It was working fine.
you can check fuse inside ok or not.
High voltage diod and capacitor OK or not.
micro oven can hold a dangerous amount of electric charge (15000V) for 15-30 minutes even after unplug.
so be careful
go for professional technician.
Jan 29, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
My 7year old kenmore microwave 721-62462 occasionally would buzz and flash behind the metal panel on the side of the microwave. This would happen off and on but without any real rhyme or reason. Today it...
ther is a high voltage generator to generate enough power to the magnetron to produce microwaves, it was probably ARCHING voltage to the body of the oven due to a faulty insulator and the paint caught on fire... as for using it well DON'T it is not safe, and will cost more to repare than a new one
Sorry!
Jan 05, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
I have a two year old kenmore 721.66462. It was working fine and then it started to make a major hum and now the food does not warm up. I disconnected it and tried the outlet with a fan and the outlet is...
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 28, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
We have a very old panasonic microwave that makes single bang sound when it is started. is it safe to operate?
When the high voltage microwave is energized, its magnetic field pulls the right side of the oven cover inward.
When the oven is manufactured, and rubber bumper is glued to the transformer.
Over the years the glue can break loose, allowing the thump to recur.
It's safe, just a little startling.
Push your hand against the right side as you start it and see if that muffles it.
If so, that's what's happening.
Dec 07, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave does not heat. Everything else works. What is the most common problem?
Disconnect power source. Take the case cover off. Inside you will find a high voltage fuse. This is probably your problem. Use safety current tools to avoid an earth shaking electrical buzz.
Elder
Feb 23, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
NEED SPEC. SHEET.
Head over to the manufacture's website.
www.searspartsdirect.com
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 21, 2009 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore oven locked out
Do you have your manual? If not, you can probably find it online and find contact inrfo for Sears support at http://www.sears.com
Nov 05, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore 62109 Microwave Oven Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
