Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Wheel in Hoover SpinSrub turbine broke
I have a Hoover Spin Scrub, Heated Cleaning steam cleaning vac with 5 brushes. I found the wheel inside the turbine is broke. The wheel catches the air and turns the shaft that tuns the brushes. I can't find that part only. Hoover parts wants to sell me the whole turbine assembley. Any ideas where to find just that part?.
  • 294 Answers
The turbine is the only way to go. ther is no way to get that part only. Your only option to find a used one is to call on other hoover dealers if the have a box of used parts that fit your model.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Oct 11, 2009
    Scholar:
  • 190 Answers
Sorry, you will not find that one part available for sale. You will need the assembly from the manufacturer, or may check online sales/auctions.
Posted on Oct 03, 2009
  • rkintz Oct 07, 2009
    The individual part you describe is not available seperately as a service part.
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vac
how do i get a manual on how to operate my hoover steam vac dual v spin scrub heated cleaning machine. i bought it used at a flea market and they did not have the manual. can you help me.
Thank you nessa
Oct 11, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Hello have a Hoover steam vac model F5906-900 serial #120500259649 use three times. The motor does not spin the brushs the square shaft does not move iam sure it is broke inside. thanks
The turbine is what turns the brushes. If the shaft on top of the brush block is ok, then the turbine isn't working, you can try cleaning it, but replacing the turbine may be the best option.
May 31, 2008 | Vacuums
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
148 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
