Every time I log into yahoo messenger I get booted off shuts down
Logging into yahoo messenger
  • Anonymous Jan 13, 2009
    I cant sign in to I.M. on my home page anymore?
I GET BOOTED OFF OF YAHOO MESSENGER AND AMS EVERY TIME I LOG ON TO YAHOO MESSENGER HOW CAN I SOLVE THIS PROBLEM THANKS PLEASE HELP ME
Posted on Feb 06, 2009
    Sergeant:
  • 291 Answers
It's beacuse of the firewall settings that the Norton program has by default, try changing them.
also
it can be for 2 reasons 1.Lines are busy at that time. 2.You have an other yahoo messenger (eg Yah mes beta) so you should deactivate 1 of them
Posted on Nov 23, 2008
I down load already but i cant sign in to yahoo msnger even my id and password are correct.
Hi aile_palomo,
If you are logged in in yahoo from the browser and then trying to log in from the messenger , then you might not be able to do so.
However at times when the server is busy , you would not be able to log in in messenger , In this case I would recommend you to wait for some time and then try logging back again.
Hope this helps...:)
May 10, 2011 | Computers & Internet
How do I stop yahoo messenger
Hi , when you enter your username and password in yahoo messenger , you are logged in. To log out of the yahoo messenger, click on messenger, which is in left top side of yahoo messenger . when the drop down open's, click on sign out. Now you are logged out of the yahoo messenger.
Feb 13, 2011 | Yahoo Messenger
Why i cannot log in to yahoo messenger my cousin yahoo ID?I
Logging into Yahoo messenger is similar in a way to logging into an email account, a log in ID and a password are required.
You mention that you are trying to log into your cousin's Yahoo messenger : has your cousin autorised you to log into his/her Yahoo messenger ? If yes, then get his/her Yahoo messenger's login ID and password & then, you can log into it.
Sep 27, 2010 | Yahoo Messenger
Log in failure
the problem you are facing is coming maximum time because of old version of yahoo, install a latest copy of yahoo messenger then log in again this will solve your yahoo messenger log in problem here is the link to download yahoo messenger
Download
Thank you for using Fixya
Regards
Manish
Jun 13, 2010 | Yahoo Messenger
It will not let me ssign in....I shut down,re-boot
1) Yahoo are concentrating their efforts to resolving sign-in issues with Messenger 10. You may have to upgrade to this version if you cannot resolve your problems and make use of the troubleshooting software - even if you want to retro install an older version later.
2) users who opt for a default browser other than IE may be neglecting to keep IE up to date unaware that IE plays a crucial part in the running of Yahoo Messenger. I use Firefox as my default but note the amount of cleaning in IE when I run ccleaner.
3) Start your trouble shooting with a clean browser
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
4) It will be worth making IE your default browser while you troubleshoot
5) Download the latest IE from Microsoft
http://www.filehippo.com/download_internet_explorer/
6) Ensure 'work offline' is unchecked :- > Tools - uncheck Work Offline.
7) Update your support software for IE using the links on this page
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
Start / control panel / programs
delete any old versions
8) If your log-in fails, interrogate the troubleshooting log for 'failed items'
Two Yahoo servers are used for initial log-ins
The log-in server checks your username and password are correct
If this has 'failed' check your IE can access a secure website by signing in here
https://login.yahoo.com/
No luck? check IE settings >Tools > Internet options > Connection tab > LAN > 'Use a proxy server for your LAN' > Advanced - Under 'Proxy address to use' check the info in 'Secure' and 'Port' are correct > OK for each window.
The connection server helps find the right location to synchronise with other servers- if this shows 'failed' change your YM settings to connect via a proxy.This can be done from the menu on the sign in page > Messenger > Preferences > Connection -adjust settings > Apply > OK
Jan 08, 2010 | Yahoo Messenger
I cannot log in because of this 81003002 problem.
There are a couple options to get rid of the problem:
1. Try restarting yahoo messenger
2. Try restarting your computer
3. Keep trying a couple more time
If this won't help, shut down the messenger and try again a bit later
Oct 02, 2009 | Yahoo Messenger
Getting booted from yahoo messenger
These days when you log in to your yahoomail along with the messenger then your are logged out from one of the service. So this problem might be becuase of you logging in both the chatting service from yahoomail as well as messenger
Jun 12, 2009 | Dell Dimension 1100 PC Desktop
Wont Log Into Messenger
We Have Had A lot Of These Lately So I'm Starting To Think Its Maybe Yahoo. But A Long shot you Could Have Messed Up Your Settings For Yahoo.
Jan 14, 2009 | Yahoo Messenger
I cannot log in to yahoo messenger
Go to Yahoo.com and try logging on,If that work,just reinstall the messenger.If not,you will need to do a password reset through yahoo
Jan 06, 2009 | Yahoo Messenger
Yahoo messenger problem
try to login to the yahoo webmail and check whether you are able to login to chat from there , If yes
Safe boot the computer and remove yahoo chat from your comp and restart and reinstall yahoo chat programme
You can also try from different chat browsers which support yahoo like Koolim.com - just to check if it is not and issue with your browser or chat programme
Mar 02, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
256 people viewed this question
David Payne
David Payne
