Question about Pioneer Premier DEH-P480MP CD Player
I just disconnected my battery. How do I reset my radio.
I have a pioneer premier
  • snuggles281 Nov 20, 2008
    the radio comes on but the volumn does not.
  • Pioneer Master
  • 5,568 Answers
You might find some help in the owner's guide:
Pioneer manuals
Posted on Nov 20, 2008
What you have to do is hold in function and the volume dial, then press function again and then up to set aux 1 once you have aux 1 press in the volume dial again and ur set
Posted on Dec 18, 2008
Again thanks to missmis44 i can help---To change your intial settings turn off the stereo, then hold down source butten until clock starts flashing then press the function button which will allow you to change your settings.
Posted on May 09, 2009
My face plate is frozen. The cd player works but nothing else what could be the problem.
First thing that I would try is to reset the radio. To do this, you would want to press the reset button (located behind the faceplate) using a bent paperclip or a ball-point pen. If this type of reset (soft reset) doesn't work, then you want to disconnect constant power from the radio (hard reset). This can be done by removing the power fuse for the radio or disconnecting the negative terminal of the car battery for about 15 seconds.
Start with those two methods. Beyond that, you may have a bad faceplate and/or a bad unit and it would need to be sent to Pioneer Electronics or an electronics repair technician. For repair estimates, I recommend visiting an authorized Pioneer retailer in your area.
Nov 17, 2011 | Pioneer DEH-P3500 CD Player
System problem (pioneer deh p670mp)
there is usually a small hole about the size of a pencil tip on the face or on the subpanel (behind the face) . it will be unmarked. you can also reset it by disconnecting the battery for a few minutes.
Apr 14, 2010 | Pioneer Premier DEH-P670MP CD Player
My car battery died, after giving the car a jump, the car started, but now my pioneer DEH-P2900MP car stereo won't work at all. could you please assist. thanks.
If you have already checked the fuse(s) that supply the radio and none are blown, you may want to try to reset the unit by disconnecting the power feed to it. Keep in mind that the radio likely has two power feeds...one for the ignition and another that keeps all memory functions up and running, even when the ignition is off. Disconnecting both of these may allow the radio to reset.
Feb 11, 2010 | Pioneer DEH-P2900MP CD Receiver...
Pioneer DEH-P580MP radio muted, can not cancel.
there is a short somewhere. check your speaker wire on the stereo to make sure none of them are shorted. also, check the speakers to make sure none of the speakers themselves are short (shorted voice coil). disconnect one speaker at-a-time to find the shorted speaker.
Jan 29, 2010 | Pioneer Premier DEH-P580MP CD Player
The radio is muted. cannot cancel.
try disconnecting the power from it by either the unhooking the battery or pulling the radio fuse. Then it should reset
How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
May 07, 2009 | Car Audio & Video
Can not get stereo in aux mode
it sounds like they've disconnected the battery on you and reset the unit.with the unit powered up (key on) If you turn off the radio by holding the source button then press and hold the function button (the round one that adjusts the volume) it takes a few seconds.......Note if you turn or move it up down or to either side it won't work. the menu will come up to change various settings including turning on the aux function.
Hope this helps!
Jan 16, 2009 | Pioneer Premier DEH-P580MP CD Player
Pioneer Premier DEH-P480MP CD Player Logo
232 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
