Question about U-Line Icemaker
Need to find cleaning solution for clr2060 ice maker. I live in
Arlington, Texas.
  • 33 Answers
I recommend using National Chemicals Nickel Safe Ice Machine Cleaner. Catalog Number NS16OZ.
****Warning**** this is a professional product!
Refer to the units instructions on how and when to use the cleaner. Directions for the cleaner amounts are on the bottle.
Go to a local resturaunt supplier and ask if they have any.
Hope this helps and please rate this!
Posted on Dec 10, 2008
I have a U-Line CLR2060 undercabinet ice maker. The unit will continue dumping batches but the interior temp never gets lower than 49 degrees F....so, ice melts about as quick as it is made. I have...
The storing compartment is not refrigerated so it will melt away the warmer ambient temperature the faster it will melt . also make sure there isn't something producing heat in the compartment
Oct 14, 2013 | U-Line Kitchen Appliances - Others
Too much ice, uint does not stop u-line CLR2060
The ice stops when the temperature reaches 34 degrees on the tube in the bin. If you have a airgap the sensor wont read the temperature properly. If you force the ice on that tube the icemaker should stop after it completes the cycle. If not. replace the board and thermistors.
Dec 18, 2009 | U-Line Icemaker
Ice cubes are hollow, freezing cycle too short. machine is clean, condenser is clean. hOW CAN i INCREASE THE ICE CUBE THICKNESS?
You don't specify a model number, but if it's one of the CLR series (e.g. CLR60, CLR2060, CLR2160) there is a small tan colored adjustable resistor 'dial' on the small circuit board located just beneath the ice bin, behind the front access panel. It should look like a round disk with teeth and has markings on it for -2, -1, 0, 1, 2.... Turn it up to +1 (or if it is already there, up one setting). Stop and restart the ice cycle. Wait 24 hours and see if that's enough or too much, and adjust further based on that. Do NOT adjust more than 1 setting in a day, per the user's manual. (And this information is IN the user's manual, so it's suggested reading.) If you don't have a CLR-series unit, then I don't know.
Jul 10, 2009 | U-Line Icemaker
Uline clr2060 produces little ice
First thing is to remove the water from the trough. Pull out the grey standpipe in the back of water trough. Then see if the grid has a good frost pattern.If the frost pattern is NOT even then you need a service call to check the sealed system. If you do have a frost pattern check to see if the water is splashing over or make sure the drain is in the bin drain hole.If water is getting in the bin then the ice can melt as fast as it makes it.Make sure your cleaning with U-line cleaner.
May 26, 2009 | U-Line Icemaker
Uline ice maker clr2060- makes ice continuously, would overflow and ice build up on condenser.
This is a problem when the thermistor in your icebin is not being satisfied.Now there is a break in the serial number to find out if you have a thermistor or a mechanical thermostat. If the serial number is before 03 (first 2 digits is the year)and the 2 digits between the dashes is 11(the month) the replace the bin thermostat. If newer then you need to replace board and thermistors.
May 04, 2009 | U-Line Icemaker
I HAVE A CLR2060 WHICH CANT START YET THE CIRCUIT BOARD GET POWER BUT THERE IS A GREEN LIGHT WHICH KEEPS BLINKING WRITTEN ON "REF VALVE" THANKS MD
if it blinks 1 time then you have a problem with your drain kinked or a bad pump.2 times you will need to replace the board and thermistors.
Feb 24, 2009 | U-Line Icemaker
We have a CLR2060. It makes ice fine for several days, then the grid freezes over. We have cleaned it recently.
What did you use to clean the grid? It must be U-line cleaner. I seen people use other cleaners just to find the same results. If the ice isnt ejecting then you can check the hotgas coil. It should be 360 ohms. If its open or week I see this from time to time. If its neither then you need a service tech to repair the sealed system . Replace the hotgas valve.
Jan 10, 2009 | U-Line Icemaker
CLR2060 Clear Ice Maker Won't Freeze
Water is not supposed to run all the time. Maybe you have a problem with your solenoid or the circuit that shuts your water. Sometimes solenoid just needs cleaning.
Aug 08, 2008 | U-Line Icemaker
U-Line Icemaker Logo
422 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
