Question about Tappan TGF320 Gas Kitchen Range
Oven wont light
I have a Tappan oven all of the top burners work. The problem is with my oven. When I turn it on the glow plug glows bright but no gas comes out.
  • Anonymous Apr 01, 2014
    igniter glows but burner wont light
    Scholar:
  • 76 Answers
Rick0192, Most likely, the bake igniter is shorted out and it has to be replaced. The part number for the igniter is 5303935066 .You can buy it for $60.00 to $80.00. If you are handy and have the right tools (Philips #1 and straight 1/4" screwdrivers, 1/4" and 5/16" nut drivers or socket wrenches, wire cutter and wire stripper) you probably can do it yourself. I would recommend to call a local appliance tech. just because of the safety issue. If you are going to do it yourself, let me know and I can help you with step by step instructions. Gendos
Posted on Dec 19, 2006
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
My stove works, the broiler works, but i cannot get the oven to work. what's the problem?
Hi, Well it sounds like the igniter on your bake element is not working. For your burner to light an igniter has to activate to turn the gas on. It is a glow plug style igniter which needs to get to a certain temp to open the gas valve. If it is bad it will not get to temp it needs to be changed. If it is glowing bright orange and the gas valve isnt opening then the solenoid on the gas valve is sticking and the gas valve will need to be changed. I hope this answered your question and helps.
Dec 09, 2010 | Tappan TGF320 Gas Kitchen Range
Oven will not heat
This can be caused by a weak/inop hot surface igniter or a defective gas control valve. First you will need to verify that the hot surface igniter is coming on(you should see it glow in the burner compartment). If it is not glowing then you will need to verify that the wiring harness has voltage to it when the oven thermostat is on. Also check the igniter for any cracks or damage and if found then replace the igniter. If it is glowing then one thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on,igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad.
Apr 01, 2010 | Tappan TGF363 Gas Kitchen Range
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
My tappan gas oven (Model # 30-4942-0005) doesn't light
yes the igniter is not calling for enough amps to open the control valve, the igniter needs to be repalced.
Feb 01, 2010 | Tappan Ovens
Oven wont light
Gas or Electric? If Gas at the bottom of oven where Oven burner is there is a glow plug ,or some might call ignitor. When it get a signal to ignite gas that glow plug gets hot and ignites gas. and that does goes Bad .
Oct 10, 2009 | Imperial Commercial Cooking Equipment...
Oven takes up to 15 minutes to light. glow plug does appear to be bright orange immediately after turning oven on. it is a propane unit.
Hi, glow plug (element) should glow red, maybe you got faulty thermocouple, located ot bottom of oven burner, unit where gas enter oven burner, they could either be gas pilot or electrical element as metering device, give a little tap, could be stuck, could also be your thermostat, check oven thermostat, many ways to check oven thermostat, give thermocouple a little tap located at beginning of oven burner, if it didn't work, call a mechnic to make futher checks. good luck.
Aug 05, 2009 | Magic Chef CGR3725 Gas Kitchen Range
Tappan - Model 36-3052-23
I suspect you may have a bad igniter. They will still glow nice and hot, but if they are weak the gas valve will not open. This is actually a safety feature. Depending on which type you have, the glow bar igniter is supposed to draw a certain current potential before the gas valve will open. Here's the current readings for both types: Round Glow Bar: 2.7 to 3.2 amps Square Glow Bar: 3.2 to 3.7 amps I would try to to determine if the igniter is good or bad before proceeding with a gas valve replacement. Generally, the igniter is a common fail item. Let me know if this helps.
Sep 06, 2007 | Tappan MGF500PBW Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
88 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
