Question about Pioneer VSX-55TXi 6.1 Channels Receiver
My pioneer receiver vsx 55txi will not turn on
Power is plugged in and it will not turn on.  Is there a fuse?  What can I do?  All of the cords seem to be plugged in.
  • deans77 Dec 20, 2008
    I have the same problem, and yes it is the fuse. My question is this, the fuse I removed was a 6.3amp 125volt 5x20mm fuse and all I seem to be able to find are 250volt fuses, either 6amp or 6.3amp., will using one of these fuses harm the receiver or will the higher voltage fuse with the same amperage be ok?
  • 3 Answers
Yes, there is a fuse inside unit on main board...just unplug receiver and take screws out of the housing (side and back) and you'll see a cylinder fuse....pull up and out and see if its blown...If it is replace with same amp rating.....
Posted on Nov 20, 2008
My pionner audio video multi changer receiver vsx-498 shuts off then turns on when the receiver is on how can i fix it
The problem is not clear. Does the unnamed multichanger turn of/on wit hthe VSX-498 or is the VSX-489 having power issues?
Is the power cord of the multichanger plugged into the back of the VSX maybe the outlet is SWITCHED with the power state of the VSX..
Jul 15, 2011 | Audio Players & Recorders
On my Pioneer vsx-55txi, the protection circuit cuts in whenever I raise the volume to a reasonable level. If I sit 10 feet or more, the volume is too low. I don't like my music or movies loud, but this...
The protection circuit is enabling because the output transistors are 1. drawing too much current causing them to heat-up 2. the transistors are going out 3. the threshold level for the quiesce state is set too high and may need to be adjusted internally. Try to cool down the Unit and see if it occurs again.
Nov 28, 2010 | Pioneer VSX-55TXi 6.1 Channels Receiver
Fuse on a Pioneer receiver?
yeah it is located in the power supply from where the power cord is attached.good luck.
Mar 01, 2010 | Pioneer VSX-819H-K A/V Receiver
My pioneer vsx-d507s keeps turning on mute randomly and I can't turn it off of mute There is no mute button. I would really like the owners manual
I have had the same problem, since there is no "mute" button on the receiver panel. My power cord on the receiver was plugged into my cable box and I was told this is not correct. I unplugged the receiver from the cable box and plugged it into my power surge protector and no more "mute"!!! Hope this helps.
Jan 01, 2010 | Pioneer VSX-D509S Receiver
Pioneer VSX-517 was turne up lou. Showe
THERMAL SHUTDOWN PROTECTORS MAY BE BLOWN
Nov 03, 2009 | Pioneer VSX-517
Doesn't turn on
does it have the blue flashing light on the power button?
Oct 02, 2009 | Pioneer VSX-815-K Receiver
No power
Press TUNE+ & AUTO SURR/DIRECT keys continuously for 2 sec. and it will tell you the fault it encountered if the receiver is in otherwise working condition.
Mar 12, 2009 | Pioneer VSX-818V-K Receiver
Pioneer VSX-55TXi 6.1 Channels Receiver Logo
206 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
