Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Motor my motors packed up where can i find where the motor goes as got a new one
    Problem Solver:
  • 5 Answers
The moter goes under the dust bin and not that easy to get to only if you known what your doing hope this as helped you
Posted on Nov 27, 2008
Keeps stopping even though I have taken it apart and checked for blockages. +
Are you sure your wall charger is working ok? You might just have a bad battery pack in the sweeper if your charger is working. Do you have a friend who knows electronics and has a voltmeter?
If so, have them check the voltage output of the charger at the plug that goes into the sweeper. Verify that the charger is indeed working ok. Then you will need to check the voltage on the battery pack inside the sweeper to see if your battery is good and holding a charge. A mechanical blockage could be something caught in the vacuum fan blade. You should be able to hold the main part of the sweeper up to your ear so you can hear and then pull the sweeper trigger and see if you can hear the motor try to start. Nothing happening may mean a dead battery pack. Regards, Dennis
Aug 15, 2015 | Dyson DC44 Animal Cordless Vacuum Handheld...
Red light flashing very fast and not charging fully
How long is it charging until the light goes from flashing red (no charge) to yellow to finally green (full charge) ? If it's not at least 2 hours, sorry I don't have my Roomba papers available, so I'm guesstimating here, it's not getting a full charge. If you can put a voltmeter on the " fully charged" battery pack, that might tell you if the charger is the problem. Clean off the metal contacts where Roomba meets the two metal contacts on the charger. Also just because a battery pack or set is new doesn't mean it's functional. I had a new Apple battery for my laptop that didn't work when I replaced an older one.
Sep 26, 2014 | iRobot Roomba 530 Robotic Vacuum
Dyson will not start
If the power cells are operational and it will not start; then either the motor is dysfunctional or something is jammed in the intake module. A conduction test with instrumentation can indicate if the motor is the problem, the power cells are not fully charged, or you have a short circuit. Check Fuses.
Feb 26, 2014 | Dyson DC44 Animal Digital Slim Cordless...
The bearings on the fan side of the motor were extremely bound. I was able to free them up with WD 40. Should I pack the bearings with grease?
the bearing on electric motors are normally sealed bearings so no dust or dirt can get into them, if i were you while you have the motor out i would get new ones the number will be on the side of the bearing and are very cheap to buy,
Nov 09, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Electrical smell, before drop in suction that comes and goes. Working fine till then, happened after I changed from a full bag to empty one. It seems that the motor might have packed up, but why so...
A strong "electrical" smell indicates that the motor is burning out. The cause is possibly worn down brushes resulting in the brush holder/s rubbing against the armature. The motor can be replaced, but I'm not sure what the price would be for parts and labor. You may be better off getting a new one
You can take it to a shop to have it checked to make sure.
Mar 02, 2011 | Numatic Henry Bagged Canister Vacuum
My phv1800 18 volt hand vac's battery seems to be running down. is there any way to revive it? if not; can i purchase a new battery to replace it? thank you!
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Jan 24, 2011 | Black & Decker PHV1800 Bagless Handheld...
How to replace battery for PHV1800 type 1 18vdc
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Manual
Here is a copy of the manual for your vacuum
www.thinkvacuums.com/pdf/uprights/Westinghouse-WST1600A.pdf
What could be the problem is the battery could be shot after not being used for so many years that the life of the battery is done. I would recommend taking it to a local vacuum store and have them take a look at the connections between where the battery goes and the motor.
Mar 22, 2010 | Westinghouse WST1600 Upright Vacuum
Won't charge and barely makes a humming noise
if you have a cheep avo meter check that the charger is charging. it should be charging about 6 volts or so DC volts? just set the meter to DC volts at 20 volts and hold the two probs on the points meter should move up, if not revers probs and try again, if not charging, get new one, but its more likly to be the battry pack in the hover gone bust on you, there a pack of ni-cads and will only last a year or so on charge,
the only other thing i can think of is the motor has given up the gost on you, as its only a toy motor in this hover! (try a friends charger first) dont go spending hard earnd cash on a dead horse, get a new one!
Oct 20, 2009 | Oreck ElectrikBroom AV-701B Handheld...
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
21 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
