Ballast UART Error
I have an optoma EP771 that powers up, shows image and then shuts off. It then blinks the error code for Ballast UART error. The power supply seems good. Not sure if this is a ballast or main board issue. What should I look for? Should I try to order the ballast. Nobody seems to know what this error actually means.
  • Nathaniel Campbell Jan 09, 2009
    I also purchased an Optoma EP771 and it turns on and shows image. After approx 1 minute, the lamp shuts down and the blinking error for Ballast UART flashes.
  • Ryan Heyworth
    Ryan Heyworth Dec 18, 2013
    I've changed my bulb and still get the same error? What does the 'ballast' refer to?
Same thing happened to me. After one minute of running, lamp shuts off and 5 power led blinks and 3 ready led blinks, indicate UART ballast error. Well, I purchased a new lamp, and installed it, and the problem was gone. I looked closely at my old lamp, and it showed a little blister inside, and a tiny spot of white residue, perhaps it was the whole problem there, although I don
Posted on Oct 03, 2010
  • Ryan Heyworth
An Optoma GT750-XL ,
GREEN BLINKING LIGHT stand for power on warming or power off cooling.
Dec 13, 2014 | Optoma GT750-XL - DLP projector - 3D 60403...
Ballast uart
The ballast powers the lamp. Keep the old lamp. I think it will work once the ballast circuitry is fixed
Dec 18, 2013 | Office Equipment & Supplies
Ballast uart error
The ballast module controls the lamp operation. There is a problem with that module
Nov 27, 2013 | Vivitek D732MX DLP Projector, 3200 ANSI...
Optoma HD70 bulb failure
I am betting that the ribbon cable to your color wheel has become loose. Here is a detailed slide show of a similar model so note where the cables are and check each one.
Optoma HD20 DLP Projector DMD repair turning green and flickering
Jun 25, 2013 | Optoma HD70 DLP Projector
Hi guys i have a Mitsubishi WD-65C9 DLP that gives me nothing but a few seconds of audio before shutting off with a blinking red light. ERROR 61
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 27, 2017 | Mitsubishi WD Televison & Video
VIZIO M320NV IT TURNS ON SHOWS THE VIZIO ON SCREEN THEN TURNS ITSELF OFF?
to diagnosed where the cause came from, first place to be done disconnect the connector that supply to the inverter board for screen back light which may have shorted line that can cause of suddenly shut off. then tried to turn on the tv with out the ballast board, if the supply from the power supply get stable and the indicator stay with out blinking that was mean the ballast board could be bad. by the way you must replaced first bulged capacitor at the power supply board. hope this can helped good luck.
Aug 12, 2012 | Televison & Video
My optoma ep771 projector, which i can't easily access right now since it's installed in our art gallery (very tall) ceiling. i think the bulb is out but i'm not sure. the light flashing situation is...
By what you have told me, the lamp possibly may have blown, so check if the product is still under warranty as you may be able to claim another lamp at no cost what-so-ever! It is however a definite code to tell you something is wrong! Hope this helps ;) ZKhan
Apr 20, 2011 | Optoma EP771 DLP Projector
Power will not come on.tried many power chords none work light will not come on
are there any leds on? if not, replace the power supply. if there are, such as one blinking red, could be the colorwheel, ballast, or the lamp has expired.
Nov 12, 2009 | Optoma EP739 Multimedia Projector
Optoma ep771 displays the word menu
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Optoma EP771 DLP Projector
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
1,798 people viewed this question
Top Televison & Video Experts
Electro Med Services...
