Question about Sony PlayStation 2 (PS2) Console
PS2 slim I have a question for you. My ps2 slim is not reading disks when i start it up it gives me two choices browser and system configuration when i push the x button it says that there is no data. My lense was melted so i thought that was the problem but when i just put the new lense part in, it still does the same thing. Do you have any other ideas... it really blows my mind that that didn't fix it.
  • krazylovin45 Nov 21, 2008
    Oh jeez... that simple?? Thank you so much I was about to pull my hair out and chuck the thing across the room. lol
  • 709 Answers
Hi Krazylovin45,
here is your solution. The New Laser lens has a solder blob added to keep static from destroying the laser diode. You will need to remove the laser once more and get some solder wick and a soldering gun. Look on the outer edge near the grooved edge and you will see a solder blob on a narrow strip of ribbon cable. You need to remove this solder to get your new laser to work. If you need pictures, google "PS2 Laser Solder blob" and you should get some links to pics.
www.PlaystationClinic.com
Posted on Nov 21, 2008
Not recognizing disk
My PS2 always does that now. Just make sure it's reading the disc in the System Browser, and it'll play fine.
Jun 27, 2009 | Sony PlayStation 2 (PS2) Console
I cannot play my dvd game on my ps2 , but my friends can play my dvd game on his ps2
Fat and Slim PS2's generally have different playability with disks. a slim, for example, does not want to play old blue-backed disks, though it will easily read PSX black backs. I'll need more information on the disk and the PS2 to give a complete answer.
Jun 11, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 (slim)
Well first off, make sure the disk if in PS1 OR PS2 format. That is what the PS2 Is requesting when it says "Please insert Playstation or Playstation 2 format disk. The Slim PS2 has various problems reading disk.(Don't Know why? I own it and Know it does). The Fat version(1st version) is a much better system, in my opionion. Try blowing air to clean the disk reader. Or changing the disk reader portion out, At a small price.
Apr 03, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
Browser shows no data on PlayStation 2 Console
I am having the same problem with my PS2, but I have an HDD inside of mine. I am told this is a circuit problem inside the PS2 that doesn't allow the information to be transfered to the RAM. That's why you see “No Data” instead of the usual problem of “Disc Read Error”. I hate to say it, but it sounds like you are going to have to do the same thing I am about to do. Send it in to Sony and get it repaired.
I am also pretty sure this PS2 you are talking about is the large fat one, and not the slim one.
Sep 03, 2008 | Sony PlayStation 2 (PS2) Console
It wont work
try and change the settings on your ps2
on the screen that says browser and system configuration press triangle.this will take you to another screen. while Playstation Driver is highlited press triangle again. this will take you to a screen that will allow you to adjust the way in which your ps2 reads discs that are inserted. try changing the settings to fast nd smooth
also some times you just have to insert the game over and over again until it works. its kinda like breaking in a new pair of shoes
Jul 25, 2008 | Sony God of War 2
Slim ps2 disk read error
I don't want to put you down or nothing but, buying the slim ps2 wasn't a great idea. If you bought the original ps2 it would've been better. The thing about the thin ps2 is the hd is small, the laser tends to become weaker faster. Go get the ps2 checked out someplace.
Jun 26, 2008 | Sony PlayStation 2 (PS2) Console
Games not play
you have a bad cdrom player. google bad ps2 laser if you want to try and fix it yourself.
Jan 04, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error
To fix this problem, you will need to open your PS2 and re-adjust its lens. To open your PS2, first turn it upside down. Remove the 4 rubber feet and 6 square tabs (circled in the picture) by sliding a flat screwdriver (or something similar) underneath them.
May 11, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
158 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
