Question about HP Pavilion dv9000z Notebook
Web cam doesn't seem to work at all
I have tried to turn on the web cam. All thathappens is it says it is broadcasting, but it is a blck picture. I have tried adjusting settings, and looked on my pc, but havent' found anytihng that makes a difference.
My lap top is a HP PPavillion dv9000
I can't start my web cam i check the properties of the unit it says its working properly. i thought my web cam malfunction so i went to a computer shop to buy a usb web cam but still it won't work...
you just need to install virtual cam then go to manycam dot com and download manycam install it and select video source your web cam
now you can broadcast your cam on everywhere like skype, yahoo, msn, gtalk etc
by select manycam as your primary cam
good luck
Aug 20, 2011 | ASUS Eee PC 900 PC Notebook
My web cam isn't working
1.try making changes in the webcam panel.and be sure the web cam can support your windows version.(old one's can't work in win7)
2.if it doesn't work REINSTALL the webcam driver .
3.if that to doesn't work webcam must have failed !!!
Jun 15, 2011 | Computers & Internet
On my DMC-TZ8 the screen says "this memory card is write -protected " how do I solve this problem , only had camera two months I have took memory card out all seems alright THANKYOU
Your memory card is either write protected or corrupted.
  • If it's write protected, it can be very easily fixed.
  1. Turn off cam.
  2. Take out the mem. card. (it's probably located near the battery. press down on it and release it. Then it will pop out.)
  3. Slide the small switch on the side of the card to the position marked with an unlocked padlock.
  4. Put card back in and turn on cam.
  • If that doesn't seem to be the problem, then it's likely that the memory card is corrupted. This is common with Flash memory that has been used extensively for a long time and this problem is likely not caused by any fault in the camera. You might not be able to access any pictures that were stored on your cam, but you can try using a data recovery software like Recuva if you want to recover pictures ( click name to download ). If you want to use the card again, You can try formatting it (differs from cam to cam, check instructions manual for specific instructions) If this doesn't work, You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk.
That's it. hope that helped.
May 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Comes up with card error
  1. Turn off cam.
May 02, 2011 | Fuji FinePix A345 Digital Camera
I am not sure if my new logitech web cam works. I
make sure it says broadcasting on it for the other person to see you
Aug 02, 2009 | Computers & Internet
Webcam broadcasting but only shows black screen
i have a logitech web cam. i want it's drivers
May 29, 2009 | Logitech Webcam
Black square problem
Go into the TVs menu and look for the closed captioning menu. Someone has inadvertantly selected the "teletext" mode. Since no broadcaster s currently using this feature, when a false signal is encountered by the TV, it throws up the black box that would contain the text data. Turn off the text function and enjoy more of the picture!
michtech
Feb 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Web cam problem
download the latest version of yahoo messanger, also check the fireweall settings
Oct 17, 2008 | Acer Aspire 5610-4648 Notebook
Obi cam wont work in messenger
If you see a black screen when broadcasting your webcam:
There may not be enough light in the room. If so, illuminate the room appropriately.
Your camera may not be functioning properly. Try your camera with the manufacturer's software.
The correct camera may not be selected by Yahoo! Messenger. To change your camera source:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Start My Webcam."
2. Click the "Messenger" menu in Yahoo! Messenger and select "Preferences."
3. Click the "Webcam" category.
4. Click the "Camera Source" button.
5. Click the pull-down menu and select the desired camera.
6. Click the "OK" button.
If you see a black screen when viewing a friend's webcam:
Check the status message at the bottom of your viewer window. If it says "Stopped," the person broadcasting has stopped broadcasting images. Ask the person to resume broadcasting and try viewing again.
If the person is in fact broadcasting and you still see a black screen in your viewer, ask them to check their camera and take the webcam compatibility test.
Oct 10, 2008 | Acer Aspire 5630 Notebook
HP Pavilion dv9000z Notebook Logo
43 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
