Hi, i'm trying to set up and install my new brother HL-2140 laser printer using the installation Disk that i recieved with the printer. The problem is that the installation is interupted because it says Microsoft doesn't recognize the software and then i get a message that "the file 'BH2140.PDD' on the brother laser printer driver disk is needed. Type the path where the file is located." Since I'm using the above mentioned disk for the installation, I'm not sure what to do. Can you help with both of these problems?
THE FILE IS ON THE DISC......STUPID BROTHER SOFTWARE JUST DO A SEARCH WITH WINDOWS ON THE INSTALL DISC..... OTHERWISE TYPE THIS FILE PATH IN... D:\install\dan\PCL\win2kxpvista
Posted on Oct 12, 2010
3 Suggested Answers
djuksoni
  • 96 Answers
SOURCE: Hi, i'm trying to set up and install my new
uninstall the driver, disconnect printer, restart pc.
start CD installation *DON'T CONNECT THE PRINTER till it ask for it.
When it report error for missing file, go to browse then locate on CD install>eng>PCL>win2kxpvista>select BH2170W then click ok.
It should be working.
Posted on Nov 27, 2009
djuksoni
  • 96 Answers
HI I WANNA INSTALL BROTHER HL 2140 but it can't wot shall i do... thanks
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download then install the printer driver : - http://www.brother.com.au/ProductsSolutions.aspx
Jul 21, 2011 | Brother HL 2140 Laser Printer
My brother 2140 laser printer keeps going offline
hold the power button for a few seconds. it worked for me :)
Feb 08, 2011 | Brother HL 2140 Laser Printer
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
Oct 05, 2010 | Brother HL 2140 Laser Printer
Brother HL 2140 printer very slow printing.
It sounds like you haven't completely removed the old print driver. To do so, you must take the following steps:
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. Right-click the printer that you want to remove, and then click Delete.
    If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Another way or removing the printer driver is this:
1. Delete the printer from control panel -> printers
2. Open Services.msc and stop and start the Print Spooler service
3. Open Print Management(Open command prompt, type in printmanagement.msc or type print management in to the start menu search box)
4. In Custom Filters -> All Drivers right click the printer driver you want to remove and select Remove Driver Package
5. Install new printer driver.
Now that you've removed the printer driver, you can go ahead and manually install the new printer driver.
To manually install you must follow the prompts carefully.
Follow the instructions in this link:
http://www.vista4beginners.com/How-to-install-local-printer
At the install the printer driver section, choose have disk and locate the printer driver that you want to be associated with this printer you are installing.
This should solve your problem.
Mar 24, 2010 | Brother HL 2140 Laser Printer
Need installi
here is the procedure to install your Brother HL-2140 laser printer and drivers
Click here to see the manual and download the drivers
Click here
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Mar 20, 2010 | Brother HL 2140 Laser Printer
Brother HL-2140 printer driver problem - won't load
Uninstall the completly the printer driver form add and remove program and dissconect the printer cable and restart the computer. after that download the latest driver from herehttp://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/monolaserpri/hl2140_all.html?reg=us&c=us&lang=en&prod=hl2140_all and install it.
Nov 13, 2009 | Brother HL 2140 Laser Printer
Hi, i'm trying to set up and install my new brother HL-2140 laser printer using the installation Disk that i received with the printer. The problem is that the installation is interupted because it says...
Hi, i'm trying to set up and install my new brother HL-2140 laser printer using the installation Disk that i recieved with the printer. The problem is that the installation is interupted because it says...
Nov 10, 2009 | Brother HL 2140 Laser Printer
I don't have a disk - can I download driver for HL-2140?
Hi!
Please use this link to download the drivers of your printer. First select the OS you are using(vista,xp or any other). Then select the language and then download the drivers for your printer.
Brother HL 2140 printer drivers
Please rate this solution.
Thanks
Rylee
Feb 11, 2009 | Brother HL 2140 Laser Printer
525 people viewed this question
