Question about Sony Playstation 3 (PS3) Console
Cant get my ps3 to connect to internet through my wireless router
Wont pick up an ip address
  • scotty2hot Jan 18, 2009
    Everytime i set up my ps3 to connect 2 the internet its gets 2 the obatining an ip address bit and always fails.
Playstation underground is merging with the playstation network i think, if you go to the playstation website under support you will find out there (because they want you to register for playstation underground in the first place). I was having a really hard time the other night staying connected to the playstation network and all that nonsense. so, if this helps - great! if it doesn't, sorry!
Posted on Nov 20, 2008
    Master:
  • 623 Answers
Assuming the media test works (So the cable/wireless connections are OK) then it's possible that you're out of available IP addresses in the router. It shouldn't be a problem (Most router configs allow for over 250 IP addresses), but it might only have limited leases.
Try switching everything off (Except for the router), restart the router and then try the PS3. That should rule out a problem with DHCP
I have wireless internet how do I get a ip address connect my ps3
The IP address is provided by the wireless router when you perform the connection process. You will need to locate your wireless network on the PS3, select it, and when prompted for the security key/code, enter it to gain a connection. Once the connection is established, the PS3 will have an IP address.
Oct 12, 2016 | Sony Playstation 3 (PS3) Console
My ps3 cant find the ip adress and has perfect internet signal
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
Error when connecting to the internet: error (80130804).
This means that your PS3 is not able to get an IP address from your wireless network/router. I would suggest set the IP address manually on your PS3 including the DNS IP address.
May 11, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont connect to wireless
Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 02, 2009 | Sony PlayStation® 3 (60 GB) Console
Can't find an IP Adrress
my friend thin may due to your new ip address.just repair it and try u can then connect.
Mar 28, 2009 | Sony PlayStation® 3 (60 GB) Console
My ps3 internet doesn't work
Easy Pie! This is a cinch anda guarantee work through. It involves putting your PS3 into a DMZ (demilitarized zone) which simply means opening all of the ports on it.
If you have the following problems, this is likely to fix it.
  • Not being able to join rooms
  • Not being able to speak over your headset
  • Not being able to hear other people over their headset
  • Not being able to join private games
  • Any problems to do with connectivity to the PSN, especially if your computer will connect to the internet, but your PS3 won't.
Part 1-(On PS3)
  • Firstly, you will need to assign your PS3 a static internal IP address. Normally whenever a device connects to your router it will be assigned a different internal IP address. These are normally 192.168.1.2, 192.168.1.3, 192.168.1.4 and so on. Assigning a static one will ensure that your PS3 will get the same one every time it connects.
  • Go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 XMB. Choose whether you are using wireless or wired.
  • Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
  • This will display a page where customizable IP Addresses are available to be entered.
  • IP Address - This will need to have the Static IP address in it. Use 192.168.1.80, simply because it is unlikely that 80 other devices will be connected at the same time.
  • Subnet Mask - always set to 255.255.255.0
  • Default Router - Is the internal IP Address of your router.
    1. To get the exact ip of your router you should go to
    2. Start
    3. Run
    4. cmd [Hit Enter]
    5. Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
  • Primary DNS - Same IP Address as "Default Router"
  • Secondary DNS - Same IP Address as "Default Router"
  • Proxy � When you get to the proxy screen, select "Do not use Proxy"
  • MTU � Automatic
  • UPnP � Enabled
Part 2-(On PC)
  • In your Internet Browser, type the address of your default gateway, this will take you to your Router Configuration Page. Look for any mention of DMZ
  • When you have found this, it will ask you for the Static IP of the DMZ host. This is simply the Internal IP that you assigned your PS3. We used 192.168.1.80.
  • Finally, turn off your Router, PC and PS3 for a few minutes to ensure that the new settings are loaded. Then you're ready to go!
Courtesy of http://www.cod4forums.com/index.php?showtopic=3460
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Unable to connect PS3 to my Secured WIreless Router
http://www.askdavetaylor.com/connect_to_the_internet_with_my_sony_psp.html
Jan 17, 2008 | Sony Playstation 3 (PS3) Console
Connecting PS3 to wireless internet
no you can not conect to the wireless you need a router for that tis is for choppee answer http://www.us.playstation.com/Support/PS3/GettingStarted/s_ps3_gs_si.html this site is to see the settings for your conection dpg7042 fixya rate
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
177 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
