Question about Indesit W 123 Front Load Washer
I have run the machine on a daily wash
It has finished and the daily wash but the clothes are still soaking wet and to wet to get out the drum. even when doing spin or a drain the clothes are still soaking. Whenever it finishes though the delay timer is on Please can someone help or offer a solution ?
thank you
  • 333 Answers
It sounds like your water discharge pump is either clogged or not working to full capacity. You can check this by looking at or feeling your discharge hose during drain and spin to see if the water is actually draing fast or just dribblig. If this is the problem then call a teck or change the pump yourself. If you do it yourself please unplug your unit before working on it. I hope this helps you.
Posted on Nov 23, 2008
My beko washing machine wont finish a full wash and the end results clothes soaking wet and suds left in drum plz help?
Usual problem pump not working or something stuck in the filter and pump flyweel needs cleaned regularly
Sep 16, 2017 | Beko Washing Machines
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
My front load washer had ue blinking after a load was supposed to be finished. The clothes were soaking wet like the washer didn't spin
UE is imbalance error...Usually because a load in the machine is unable to distribute itself around the inner drum, and the machine senses the load as imbalanced.....Good Luck Nomess
May 21, 2010 | LG WM-2277HW Front Load Washer
I am very unhappy with this machine and sorry I bought it! It uses so little water that sometimes when I take the clothes out after it is finished washing I can see dry spots on the clothes that never even...
How about putting the clothes in and pouring water over them with a jug before the washer starts its program ?.
It could also be that the water level switch is out of tolerance and needs replacing
Most machines have a pre-wash cycle as well
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
WHIRLPOOL LXR7244JQ1 CLOTHES ARE STILL SOAKING WET
More than likely motor has lost a stage in it. I would replace it.
Jun 29, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Feb 16, 2008 | GE WSXH208A Front Load Washer
Indesit W 123 Front Load Washer Logo
278 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
