Question about NEC Dterm DTP 16D-1 Corded Phone
Update company message when on auto attendant (night mode)
We are trying to figure out how to change the company's message to reflect changes to the mailboxes, but the one help I found said we need to have system administrator rights. What are these, how do we know who has them, and are they absolutely necessary? What if we forgot the information necessary for this? Thanks for your help.
  • evmich Nov 20, 2008
    Sorry, I forgot to tell you what kind of phone we have: NEC Dterm 80 model# DTH-16D-2(BK)TEL
    thanks
    Problem Solver:
  • 13 Answers
Although this has probably been solved. The solution would be to have each user dial voice mail and log into their mailbox. Once logged in press 0 (zero), if you are given more options then this is the administrator's box. Follow the prompts to change the company greeting for day or night mode. If this does not work you will need to call a qualified technician who will log into the voice mail with a PC.
Posted on Dec 08, 2008
When I put my t7316E on "night" it only rings half ring then sends call to answer machine, Any way to change to a few rings so I can answer it if needed
That is generally how Night mode works - alerting you to a call then directing the caller to voicmail night message. You want to change the Forward No Answer setting in that mode; if your system doesn't support that, set FNA in regular (non-Night) for the attendant phone.
Oct 09, 2014 | Nortel T7316E 2-Line Corded Phone
I have a Panasonic KX-T7433 and want to change the Auto Attendant message. How do I do this?
An auto attendant in a Panasonic brand voice mail system (TVS/TVA/TVM etc.) is controlled from the message manager's phone. It is accessed by calling 165 and dialing #6 *998
Unfortunately, your question has no hard answer. Each voice mail and auto attendant is different. For example, in TVS boxes, we use custom greetings and store day messages in 30 and night in 60. There are 100 "custom" greeting slots and 32 "company" slots in a TVS box. In the newer TVA systems, the interface is visual and custom messages get assigned sequentially. In those systems, we start with 1 day and 2 night.
So, the best answer is to find the installation instructions. If you can't, then you can step through each custom greeting for the existing one, or log into the VM system and read the database.
Carl
Feb 16, 2011 | Panasonic KX-T7453 Corded Phone
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
CHANGE NAME ON DIRECTORY AFTER COMPANY GREETING
Hi there, Cangeletti...
Ok, so you need to change the greeting for the Auto attendant then.
First thing, these new employees have the extensions of the old employees correct, otherwise more changes that what I gave you here will not work properly, example when you hear Press 1 it went to Joe, and Mary is where Joe used to be; that will work. But it Mary is where Steve used to be, pressing one will go where Joe was and not to Mary. Understand?
Ok, for the first part- changing the greeting in the Auto Attendant via CCR tree... you have to get into the ADMIN mailbox:
-> FEATURE 9 8 3
-> Password 1020000 (this is the default password, but can be changed)
-> OTHR
-> CCR
-> ADMIN
-> TREE 1 and press OK
-> CHNG
-> Path 0
-> REC then press PLAY to listen to the greeting, and ensure that is the one that you need to change
-> REC the new message
-> remember to SAVE! otherwise all is for not.
THIS MAY BE REQUIRED FOR OTHER TREES ex 2 or 3, listen too all trees and change if required... same steps to get into the trees and prompts.
Sep 14, 2009 | NorStar M7310 Corded Phone
Change new greeting removed old greeting
Sounds like you might be changing the wrong greeting. If your using a night button to toggle the auto attendant on and off the auto attendant is using the night greeting.
Aug 28, 2009 | Lucent PARTNER18 Corded Phone
How do I change the main message , the person who recorded the main message is no longer with the company and the information that is recorded is wrong . None of us know how to fix this problem. It is a...
Pasrtner MAil VS
dial into voicemail (intercom 777)
enter mailbox 99#
password is 1234# (default password)
press 9
press 3 for auto attendants
press 1 for day 2 for night
press 6 to modify
press * #
record here.
Press * # to save before hhanging up.
Jul 31, 2009 | Lucent PARTNER18 Corded Phone
I am in need of changing the night rining service message on the M7310. I have read the manual over and over and can not figure it out. Any help would be appreciated.
First of all, there are different locations for each greeting...
and you have to know which greeting you are changing.
The greeting that you are talking about:
-> is it the CCR tree? (is says - press 1 for x, press 2 for y, press 3 for z)
-> is it the Auto Attendant? (welcome to xyz company, if you know the extension of the party dial it anytime)
-> is it the General Mail box?(please leave a message after the beep)
-> is it the receptionist mailbox?(this is the receptionist personal mailbox)
In other words, what does the greeting say, maybe that might help solve this issue.
Jun 24, 2009 | NorStar M7310 Corded Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Enable Custom Messages
It's hard to see what you recorded the custom messages on, since you left that part out.
I'm guessing that whatever you recorded the messages on has a manual. Try reading it. Is your day greeting a custom message or is it one of the 32 announcements? However you play that message, you need to either replace it, or assign a new message or mode to the auto attendant.
Carl
Aug 25, 2008 | Panasonic KX-T7453 Corded Phone
Setting our nigh-time message
Where is this message "set?" It should be in a custom service in your automated attendant. Which Custom Service is set up by your installer under Time Service for Night Mode. In addition, your Automated Attendant has to have a correct schedule to designate when Night Mode is in effect or be set to be under PBX Control. If the latter is true, your greeting will automatically play when you put the system in Night Mode.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jun 20, 2008 | Panasonic KX-T7633 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
678 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
