Question about SanDisk Sansa e250 MP3 Player
Static on the Screen (please help)
When I turn my sansa e250 on, about 90% of the time the screen malfunctions and only shows static. Normally I'd assume that the screen was broken, but every now and then I'll turn the player on and the screen will work perfectly However, chances are that when the screen is working perfectly, if i turn the player off and restart it, I'll be stuck with static for the rest of the day Is this a software issue? A loose connection? Please help Note: Whatever state the screen is initially in when I turn the player on is the state that it remains in until I turn it off or restart it. So if the screen is working, it will stay working until I turn the player off. Same goes if its full of static Also: the player itself works perfectly regardless of the state of the screen. its just a pain manuvering around the menu blindly
  • blag-diva Mar 06, 2008
    when i turn on my mp3 player it just keep on restarting its self what do i do?
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Adesso AKB-430UG touchpad problem
It is common if you have a static charge for the cursor to flick all over the screen as the static build up causes a malfunction with the screen. If you have nylon carpets or fabric on your chairs which builds a static charge this will make things worse. Try using the screen on a wooden table where there is a wooden floor and sit on a wooden chair. Before you do anything touch your hands onto something nearby and hold them there for a few seconds to get rid of the static charge. Then turn the power on to the screen while holding on to it. If it all works OK then you can be sure it was a static build up. Then try walking away for a minute or two and then try it again. If the cursor flicks all over the screen, you have got a static build up on your body. This is surprisingly common with laptops or similar devices when people use them on their laps while sitting on couches.
Dec 08, 2017 | Adesso (ACK-730PB) Touchpad, Keyboard
My camera has like some kind of static in the screen
Have you tried cleaning the heads? It went away for me when I did this. buy cleaning tapes and follow directions.
Dec 13, 2009 | Canon GL2 Mini DV Digital Camcorder
Game freezes and screen gets full of static
open your PS3 up and use a dust cleaner to blow the dust off!it could be overheating. and if that works next time you play pull it out of a confined place and when youre done wrap it in a towel and put if where it should be to prevent dust getting in
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
Exilim z600 Static on viewing screen. Sometimes won't turn on/off
More than likely, you've just got a bad camera. I've helped with several problems with P/S cameras where the screens are either noisey or records a static like image. 9 times out of 10, it's the processor. Unless the camera is new or still under extended warranty..,
Feb 04, 2009 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Grey static then flashing button
Could be your flyback transformer or these caps 2200 mf16v 22035v 33035v. Check the caps for bulging.
Jul 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
When I turn on the TV the screen has static
Static usually means that the tuner is not working. Chack all of your cable connections first. As a quick test of the tuner itself, remove the cable from the exterior antenna connection and insert a small paper clip. That will act like an antenna and if you scan for channels, something should be seen. If not, then you probably have a bad tuner or have lost the source power for the tuner.
Dan
May 07, 2008 | Toshiba 50H81 50" Rear Projection...
Static screen
Push the reset button along with the power button. That resets all memory in it and tends to fix the static fuzz.
FYI: The static show on the screen after putting the batteries in backward.
Feb 14, 2008 | Palm M100
Sansa e250 frozen white screen
hold the power button and forward button together for 2 minutes
Jan 02, 2008 | SanDisk Sansa e250 MP3 Player
Static on screen and then turns itself off then on
My first aproach will be to see if the tv reacts to tap on the sides if you see a reaccion when you do it most likely you have a loose conection and need to call someone to find it and resoldered it.Dont do it yourself if you dont know how.
Sep 11, 2006 | Proscan PS27125 27" TV
SanDisk Sansa e250 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
