Question about Siemens SpeedStream 5260 ADSL LAN Modem p/n 060-5260-003 (SPEEDSTREAM5260)
Can't get modem to work
Recently got a used SpeedStream 5260 modem and it does not want to work. All the connections are correct but the modem just sits there with all 4 of its lights solid green and won't connect (sys, atm, dsl, enet) My windows XP brought up a repair tool to test out what the problem is and it wasn't able to figure it out. Any ideas what the problem could be? Thank you.
    Scholar:
  • 53 Answers
Speedstream 5260 modems don't have a built-in pppoe in it, so with your win xp OS you just have to make a broadband connection using the new connection wizard by either going to control panel > network connection > new connection wizard or in internet explorer, click on tools menu > internet options > connection tab > click on setup button. follow the wizard and type your username & password on your registered internet account. also make sure you delete your previous broadband connections (if you have set up one before) to avoid conflict with the new connection.
the set up is different if you are using lower versions of windows OS, (like win2000, ME, 98 SE/ FE or 95? ) or Mac 9 you may need to install a pppoe software such as Enternet 300, WinPoet, etc.
Posted on Apr 23, 2008
The dsl light in blinkin red and green why? What is the problem.
Olease any help
Posted on May 26, 2008
  • 43 Answers
Might be possible that your computer is not responding with the modem == if the light are solid on the modem == checke this out ===>> click on start button ===>> now click on run type in the box cmd == you will get a balck screen = now type ping 192.168.1.1 and checked if the computer is giving replys ... if you get this then contact me back
Posted on Apr 27, 2007
Wireless facility does not work LED does not illuminate. I have tried to get access to web site
The connection to your modem could be faulty.
Ring your ISP and get them to test the connection to your ADSL modem.
Also do you have ADSL line filters on all your phones?
The phone connection to the ADSL modem does NOT use a ADSL filter.
Dec 13, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
My Bsnl Siemens Adsl modem takes a lot of time to get the link,please help!
it is not your modem it is definetly BSNL. but if you can afford then try either switching to other adsl service or changing your modem.
Jul 18, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
I installed a Dlink Telephone adaptor between my speedstream 5260 my PC. I think I need to change the MAC address on the speedstream. How do I do that?
Connect one of your computer to the LAN port of the speedstream, access the configuration page of the speedstream (example 192.168.1.254) then under advance tab there a MAC filter there that you change the MAC address.
Mar 15, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
My modem is not working, all the light are solid green but is not conecting to the internet.
Click the Edit menu, click Find, then click People.
Select the Internet directory service you want to search at the top, type in the person's name, then click Find Now.
Feb 19, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
Modem cold to touch
hey hi,
frequent disconnectes suggest tat u might have an intermittent sync prob that might be due to,
1 )filter problem(filter is a small box ,it is also called as splitter that splits ur broad band connectivity and telephone line)
so try isolating the filter that isz
connect the cable runnin at the back of ur modem directly into ur wall jack.
this will probably solve the problem
2)next reason is , it might be a line issue pls cal ur broad band help desk they ll sort it out
ur modems temperature has nothing to do with this.
try this n let me know .
Oct 01, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
Speedstream 5260 (5262) //EnterNet300
i m sorry to say that enternet300 1.5c is not available these days in online.
instead of enternet , windows xp has a similar built in interface, its 99% similar to enternet
try configurin your isp using this simple procedure, configuring this interface is pretty easy compared to enternet.
so go ahead and give a try . i m sure u wont regret !
•Go to Start->Control Panel •Then Network & Internet Connections
•Then Network Connections
•Select Create a new Connection
•Click Next
•Select Connect to the Internet then click Next
•Select Set up my connection manually then click Next
•Select Connect using a broadband connection that requires a user name and password then click Next
•Type in your ISP's name then click Next (**See Note Below)
•Enter your user name as provided by your ISP.
for example: You might need to inlude your domain as part of your username. pacbelluser@pacbell.net
•Enter your password, then confirm it
•Select Use this account name
•Select Make this the default Internet connection then click Next
•Select Add a shortcut to this connection to your desktop then click Next
•Hit Connect
i guess this must resolve your issue :)
Jan 30, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
Speedstream 5260
there is a problem with yur dsl connection check for physical setup between the modem and the telephone wall jack
if the problem exists contact your isp
if u r not too sure abt the physical setup pls contact your isp providers and they will help you to run through the steps
Jan 16, 2008 | Efficient Networks SpeedStream 5260...
Speedstream 5100
FOR AOL Instructions see the first question in
http://www.smallbusinesscomputing.com/we...
As far as configuring the router try
http://www.dslreports.com/faq/efficient/7_Misc._Questions
or
www.waymark.net/tech_support/DSL/SBC/5260.pdf
or
http://whirlpool.net.au/index.cfm?a=h_view&model_id=112
FROM THE SECOND LINK --
Installation Requirements
To install the 5260 ADSL LAN modem, you will need the following:
• A computer equipped with an Ethernet network interface card (NIC) or
an Ethernet hub
• A DSL-ready telephone line installed at the desired installation site
Package Contents
Your package should contain the items listed below. If anything is missing
or damaged, please contact the dealer from whom the equipment was
purchased.
• 5260 LAN modem unit
• Power supply
• One RJ11 unshielded twisted pair (UTP) cable (for the DSL connection)
• One RJ45 UTP straight-through cable (for direct connection to a PC
with a NIC installed)
• Installation Guide, Safety and Certification booklet, and Release Notes
(if applicable).
Nov 29, 2007 | Efficient Networks SpeedStream 5260...
Belkin Router - Network works for 5 minutes than everything loses internet capability.
hi,
           This issue usally occurs when the router is able to save the data stored or in  other words the Router id not able to AUTHENTICATE,  but as you already got a new router and you have already done the fireware upgradation of the router. we can also upgrade the firmware of your speedstream modem.
plz do these following steps ,( plz disconect the router from the computer and modem completly while doing the steps )
The Efficient 5260 modems that can be upgraded are as follows:
Look on the label on the bottom of your modem. It should read:
SpeedStream 5260 Ethernet ADSL Modem
Part Number: 060-5660-00x (where x=any number)
Revision: any (all revisions seem to work)
If your part number reads anything else, your modem is most likely not upgradable.
For those curious, 5660 models 003 and earlier do NOT support G.Lite ADSL, only DMT. If you are buying a 5260 or 5660 model secondhand, and your DSL ISP uses G.Lite DSL, it would be a good idea to check with the person selling you the DSL modem.
UPDATE: As of 5660 Firmware v2.3.0(2) and later all 5660 including 5260/5660 hybrids support G.Lite ADSL. It pays to use the latest Firmware.
PLZ REPLY IF THIS HELPS, I WILL TRY TO FIND OUT THE RESOLUTION FOR THIS ISSUE
REGARDS.
Gunjan ';';';';';';';
Oct 18, 2007 | Belkin (F5D8231-4) Wireless Router...
Wont work
Does Big Pond and your new ISP dodo use the same values for VPI/VCI?
If not, you need the correct VPI/VCI for your new ISP.
Read the FAQ at DSL Reports on the 5260 and changing the VPI/VCI using EnterNet 300 1.5b or EnterNet 300 1.5c.
http://www.dslreports.com/faq/15476
Regards,
Doctor Olds
Oct 16, 2007 | Siemens SpeedStream 5260 ADSL LAN Modem...
Computers & Internet Logo
342 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
