Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
IC Power 19'' LCD Product PA192D Model # 900G quit working
I turned off the room power for a few hours, turned it back on, and everything came on as normal except this monitor. No LED, no indicator what so ever. Have trested cord, and there is power. Still, I changed cords, and changed outlets. No operation. Monitor working fine this AM. Someone mentioned a power board/inverter? There is also a slot in the back that has a lock symbol and "K" stamped in the lock...???
Can't find anything on this monitor.
Pls advise! Thank you!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
I C Power PA192D Model 900G, Mfg Sep '05 19inch LCD
I purchased this monitor at Goodwill not working for $20. The 900G power light failed to come on and there was no video when turned on. To fix, first pull the 2 screws at the bottom of the back side of the monitor_ note this face is NOT removed by prying with a screwdriver like other monitors, it IS removed by sliding the face plate Upwards. Remove the LCD screws and remove the wires to the backlights carefully noting what goes where. Remove the metal cover and remove the 110volt power board. I found smoke trails under the cover and a swollen 470uf25v capacitor number C206, and replaced C110, C211 all were 470uf. Reassembled and found no change. Tore down again, used the ESR meter CapAnalyzer 88a and found C114 47uf25v to be 30% working, the volt ohm showed the cap to be good, that's why the ESR meter was needed. Replaced the 47uf25v C114, tested the large 100uf 450v capacitor, it tested only slightly under spec , could not find a 100uf at Radio Shack so did not replace it. So in this attempt the only thing changed was the 47uf C114. Reassembled and now works perfectly.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Posted on Jan 02, 2009
I have ac Acer S202HL LCd monitor. When I booted up one day it didnt come on.
first check with your both power supply out put is coming 19 Volts dc.
if its not coming check with multi meter primary and secondary of your adopter continuity.if no continuity replace with proper working adopter.
Nov 07, 2013 | Acer S202HL LCD Monitor
Gateway 19" lcd color monitor, product no. fpd1960 model no. 900g
The most common cause of power up issues with the Gateway FPD1960 monitor is a failure of the filter capacitors on the AIP-0100 power supply board in the unit. Here is a link to repair information for that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=206
Nov 14, 2012 | Computers & Internet
I got a Gateway LCD 900G monitor, it keeps flickering and making hissing noises, what can i do?
Flickering could be a loose power connection but the hissing is indicative of a potential short. for your own safety, I'd get this to a TV type repairman asap.
Dec 25, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway 900G does not stay on, has power
the_princes, On the rear side of LCD screen that you look at are two each long, straight, cold-cathode-fluorescent-tubes that need to "LIGHT-UP"and provide pure WHITE light to be reflected through the LCD glass panel that you look at from the front side! If you don't have any luck with Gateway providing warranty service or doing a swapout with them, then you should possibly look into having it Refurbished by someone locally in your area. I highly recommend that you go to youtube and watch some video clips of LCD MONITOR REPAIR to see exactly what you are getting involved with. When making a post to tthis site you should always give some "history" along with the trouble "symptom" such as how old is unit and approximate total amount of "ON" time the unit has. I hope you can use the info provided. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Oct 01, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway 900g no power
Try a different working out to make sure its not a wall outlet issue.if you do that and your still not getting power then the monitor is bad and would need to be replaced.
Aug 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Hp lcd monitor turns off after 4 or 5 hours
have you checked the soldering to see if theres any dry joints?
Jul 21, 2009 | Samsung 997DF 19" CRT Monitor
No power/dead
try to turn it on the power switch on monitor.....and make sure all connection are ok
Mar 06, 2009 | BenQ FP731 - 17" LCD Monitor
IC Power 19'' LCD-Will not Power Up- No Lites.
This is a follow up to my last submission about my discovery of bad caps on the FPD1960 LCD flat screen Gateway 19" computer monitor. To recap: After two and a half years of excellent graphics quality, my monitor suddenly went blackout. After pushing the power-on button, the screen would come on for 1-second, then go black. Repeat, again and again, same result; comes on for 1 second then blackout. THE REPAIR: After carefully but forcefully prying open the case, I unscrewed and unplugged then removed the screen and set it aside, then unscrewed and removed the power supply board. Sure as shootin, bulging (and slightly leaking) capacitors were immdiately apparant on this board. That other fella's submission was right on target. Search Wikipedia for "bulging capacitors" to get the inside scoop on this widespread problem. Major manufacturers are well aware of this issue, but fortunately for them it occurs some 2-years out'a the box, and after the warranty expires. This is one time I wish I'd bought the extended warranty! Anyway, I finally got my 5 caps from Ebay in the mail today. Specifically, they are 470uF 25volt 105-degree (use only 105's because some are right near a power transister heat sink---so I'll bet they get mighty friggin hot. After carefully replacing the old caps with the new (you'll need a solder ****** along with your solder iron), I reassembled, powered-up, and began to thoroughly enjoy the fruits of my labor. It's working like new once again. THE CAPS ON THE POWER SUPPLY BOARD ARE DEFECTIVE.
Nov 20, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway 19 in flat monitor Model 900G
Does the power button light up or blink at all ?
It probably is the power board/ inverter. I fix many of these.
To TeeKO, did you try moving it back to see if it was maybe a bad household receptical ?
ebaysbammbammfran
Jul 29, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
1,036 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
