Question about HP Pavilion a622n (PC108A) PC Desktop
Problem getting computer to turn on
I just moved my computer to a new location and then I went to turn it on. But the power light keeps flashing and the computer does not do anything. The monitor will turn on. Please tell me what the problem is.
  • Anonymous Feb 20, 2008
    I powered down my computer and replaced my ancient surge protector with a new one. When I plugged the desktop back in, the power button blinks like a disco light, but the unit will not turn back on.
  • CraigD Feb 20, 2008
    I have unplugged the unit, let it sit for a while and then plugged it
    back in, to no avail. I have tried plugging it into multiple outlets,
    but the only result is more disco lights.
    I'd look on the bright side and say that I could make the best of the
    situation by dancing to the beat, but then all of my music is on this
    non-functioning computer. . .
    President:
  • 2,961 Answers
Try removing the power lead from the back of pc for atleast 15 minutes and re-connect. It may be a power supply unit fault that is showing connection but not powering the motherboard. Open up the side of pc and check the main leads that come from the power supply unit to the motherboard connection are'nt dissloged in any way, or unplug the motherboard connector and place in again this might re-set it.
Posted on Dec 21, 2006
SOURCE:
Flashing o/d light flashing and causes gas and electrical power to drop
Flashing o/d light is a "check engine" light for your transmission. Codes can be in the main computer so get it obf2 scanned, but better to head to good transmission shop. Noise likely in the trans.
Jan 23, 2018 | 2001 Kia Spectra
Touch screen wont turn on power light keeps flashing green, rapidly, worked right up till we moved it to a new computer. what do i do?
It may be that the cord you have plugged into the tower either a.) doesn't like the plug in or b.) your going to need to adjust power and voltage settings to the monitor
Oct 30, 2010 | Elotouch 17" LCD Monitor
I HAVE A MISUBSHI TV MODEL #WD57734. THE TV WENT OUT AND THE LAMP LIGHT CAME ON. i REPLACED THE LAMP AND KNOW THE LAMP LIGHT AND POWER LIGHT ARE BLINKING AND IT WONT TURN ON.
Try resetting the set, there is a reset on the front of the tv where the power button is located, just stick the point of an ink pen it it and it will reset itself, if this does not work make sure the lamp door is secure.
Dec 04, 2009 | Televison & Video
I have a WS-65711 Mitsubishi rear projection the power went out last nite and now it wont turn on and the yellow light just keep flashing and when i reset it the light just keeps flashing
you need to buy a new tv when your power went out it was fine when it came back on it surged and fried components in the tv same thing happend to me but i lost my computer vcr tv dvd player and monotor
Jul 04, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Dimension 5100 wont power up
check powersupply, boot into recovery console and run chkdsk /r if able, and yes you can mirror the drive and recover data. may also be able to do repair install.
Dec 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Installed a lexmark z12 printer but not the power light but the light next to it keeps flashing and it wont print
  1. Turn the power OFF.
  2. Open the front cover.
  3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer.
  4. If it does not, close and reopen the cover:
  5. Remove the color print cartridge.
  6. Close the cover.
  7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
  8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
  9. Remove the black print cartridge and reinsert the color cartridge.
  10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
  11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
LG1717S - Power light flashing - no image.
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 03, 2008 | LG L1717S-BN 17" LCD Monitor
Light blinks continuously....
open flap to access cartridges hold down power button untill cartridges move to centre remove and reinstall cartridges set them as new in the pop up box window and print a test page worked 4 me,i had a continuous flashing green light
Aug 05, 2008 | Lexmark Z640 InkJet Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
HP Pavilion a622n (PC108A) PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
