Question about Compaq Deskpro EN 6500+ Model 6400 CDS PC Desktop
Non-system disk or disk error
I've had my computer for a few years and all the sudden one day I turn it on and get the error message ''Non-system disk or disk error, replace and strike any key when ready''. I've read everywhere online and the first thing everyone says is check the floppy drive. Well, there's nothing there. Haha. I just want to be able to boot my computer and/or get the pictures, etc. off of it.. if possible. Someone helppppp! =)
  • Anonymous Feb 05, 2009
    how to solve the problem? "Non-System disk or disk error"? please help me. my pc is window 2000
I tried making a boot cd from the internet because i never had one, and switched the boot order.. but it didn't seem to work. it read the cd for a couple seconds and that was it.. back to that stupid message. =( how do i know if it's recognizing the HDD? and if it isn't, then what do i do?
Posted on Nov 24, 2008
    Scholar:
  • 78 Answers
Also make sure there are no CD's in the CD Drive. The computer will attempt to boot from the designated / preferred location. I.E. If "Boot from CD" is listed as the first device, it will try to boot from there first if it sees a CD. If it is trying to boot from the HDD as expected, and it doesn't find the boot sector, it will then try other options. Check the CMOS to see if you can find the boot preferences, and if necessary, change them to meet your requiremens, of if you are lost for an answer, set for default. To get too the CMOS, typically press the DEL or F2 or F1 key immediately after switch on. You can press it several times until is says "entering CMOS / Setup, or similar".
While in the CMOS area, make sure the computer is recognizing the HDD, as it is possible the HDD has failed. Your problem may well require further diagnosis if these don't help.
Posted on Nov 20, 2008
  • 79 Answers
Hi there
try changing the boot order
press F6 or F8 4 or 5 times on start up
when you are in bios mode use the arrow keys to select boot order option
select hard drive
save and exit
restart
hope this is helpful
beergut707
What do i do when my computer shows the message non system disk or disk error
If your hard disk can detect on BIOS Setup,There is a problem on your hard disk. Whether the installed OS is corrupted or the hard disk itself have bad sectors. Sometimes Master Boot Record (MBR) issue. Try to make fresh install of OS
Feb 23, 2013 | HEWLETT-PACKARD 620 XT964UT Notebook PC
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
My hp laptop shows non system disk or disk error
Apr 04, 2012 | HEWLETT-PACKARD MINI 5103 Netbook
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
The system operating system not found
You will need to format and reinstall the operating system.
insert the windows/restore cd, turn on the power, press a key when it directs you to and run through the setup process.
Sep 27, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
Non system disk error or disk error when turned on
this happen when the computer does not detect the hard disk, check the cable and power connections of the hard disk
Sep 03, 2009 | Computers & Internet
I have a HP 8595c computer. I put a DVD in and it froze. I restarted the computer and now it won't boot up proberly. I get this message. "Non-System disk or disk error Replace and strike any key...
Non-System Disk or Disk Error results when the Basic Input/Output System (BIOS) cannot find the boot sector or the master boot record is missing or damaged; i.e. the device does not have bootable media. The BIOS searches drives in the order usually specified in the CMOS Setup. This order is often, but not always, A: (floppy drive), C: (first partition on the hard disk)… The error will occur during startup if the CMOS is set so the BIOS seeks the floppy drive first and a non-bootable (or blank) floppy is in (was left in) the floppy drive. Other causes include:
No bootable partition on a hard disk drive
  • A defective hard disk drive
  • The CMOS drive settings (parameters) are not correct for the boot device
  • Defective floppy
  • Defective floppy drive
  • A virus
  • Jul 21, 2008 | Computers & Internet
    Hard drive recovery, hard drive is damaged
    My brother's MacBook Pro had a similar issue a few years ago. In his case the issue started when he attempted to update the OS to the then most recent version. The update failed with an error saying that the Hard Disk needed to be repaired and instructing him to restart in Recovery Mode and repair the disk. When he did this the "Repair Disk" option was grayed out as you said. From my searches then it seems that the drive entered a "write-locked" state that prevented it from mounting. I was able to recover his files and restore the computer to working order. You will need another computer that has enough free space to hold the files you want to save, and the appropriate cable to connect the misbehaving computer to the working computer.
    This procedure requires booting in Recovery Mode and erasing the non-working computer's hard drive, reformatting it, and restoring the system.
    1. Turn on the working computer.
    2. Make sure the non-working computer is turned off, connect the two computers using the appropriate cable (FireWire or Thunderbolt)
    3. Turn on the non-working computer holding down the "T" key to enter Target Disk Mode. (This worked in the case of my brother's computer, but I can't guarantee that this will work in your case, but if you could get it into Verbose mode I would think you should be able to get into Target Disk Mode.)
    4. The non-working computer's hard drive icon should appear on the working computer's desktop. You may get a message that you cannot alter the contents of the external drive (non-working computer), but you will be able to transfer files from the non-working machine to the working one.
    NOTE: You could connect a dedicated external drive to the working computer and transfer files from the non-working computer to the external drive using the working computer as an intermediary of sorts.
    5. Transfer the files you wish to save. We will be erasing the non-working computer's drive and restoring the system so be certain you have what you need transferred before you get to that step.
    6. Once you have saved all of the files you need to save, you can eject the non-working computer's hard drive, and turn off the non-working computer.
    7. If possible connect the computer to the internet, if not possible you can use wi-fi, but it may take longer.
    8. Connect the non-working computer to the drive with your most recent backup.
    8. Turn on the non-working computer holding down the "Command+R" keys.
    9. Once the computer is in Recovery Mode choose the option to Restore From Backup
    10. You will then be asked to choose which backup to use, and then click "Restore". Once this process is done you should be able to boot the system. You can then transfer the files you saved to the other computer or external hard drive back to the restored computer.
    Mac Data Recovery Recover Lost Data with Ease
    Jun 18, 2008 | Western Digital Caviar WD2500BB 250 GB...
    Cannot edit product key. Error wtiting the values new contents.
    the non genuine copy messed you up.
    you have to either find the original Operating System disk, get a replacement from the manufacturer, or buy a new one and reinstall.
    There is no legal getting around this.
    Oct 21, 2007 | Acer Aspire 3680 Laptop
    Compaq Deskpro EN 6500+ Model 6400 CDS PC Desktop Logo
    113 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
