Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Need a programing guide for 9p5034c102
Lost remote and bought a universal remote but the volume will not work- the light blinks but no sound
Need manuel to turn tv on
Posted on Nov 29, 2008
What is the code to use for universal remotes
i found that your brand is not RCA universal remote code list..
if your are using RCA controller follow the steps below
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE
SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad, press the number buttons in order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have retrieved all three numbers in code
if you are not having RCA controller or the method above is not works then buy new GE universal remote
solution using GE controller
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
i hope this will work
regards,
cseian
May 01, 2010 | Vivitek V37655 56" DLP TV
How to program to use with my universal remote to work?
YOU HAVE TO HAVE THE PROSCAN REMOTE OR BUY BETTER REMOTE
Aug 24, 2009 | Televison & Video
Lost remote need code for universal remote control.
  1. Turn on your TV.
  2. On your Tune In remote, press TV and release.
  3. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  4. Enter the first three-digit TV code for your NEC from the list which follows:
    030, 056, 019
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  5. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
May 11, 2009 | Televison & Video
Lost directions to program philips universal remote. I have a zenith tv.
All I needed was a four diget code. I dropped the eight dollar remote which caused the batteries to fall out. I just went to Wal Mart and bought a new one.
Nov 03, 2008 | Televison & Video
Can't find remote code for my Magnovox TP2783C101 TV, I bought a RCA Universal remote.
If the remote was older stock, it may not have all the codes listed in the user guide.
This site may have some codes not listed:
http://www.thompsontv.com/rcarc.html
If this doesn't help, there are numerous sites listed by Google:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-37,GGLG:en&q=RCA+%22universal+remote%22+codes
Most 'universal' remotes really aren't all that 'universal.'
We have two sets at home for which no one seems to have codes and one of them won't even program a 'learning remote' which is what you might need.
Jun 30, 2008 | Televison & Video
My grandmother needs the code her GE universal remote to operate her Sharp TV. Thanks
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed, try the Code
Search method described below.
Possible codes, seeing as each tv is different you will have to try until one works, the third list is for models bought before August 2002
found all of the below info at http://www.jascoproducts.com/support/universal-Remote-codes.asp
SHARP .... 0079 0123 0063 0020 0004
....... 0009 0226 0266 0006 0095 0122
SHARP
591, 604, 729, 671, 679, 684, 809
Sharp
004, 006, 012, 029, 095, 111, 112, 113, 122, 171, 173
Let me know if you have any questions, please don't forget to rate my solution after you fix the problem
Apr 25, 2008 | Televison & Video
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
