Question about JVC MX-D301T Shelf System
Unable to play cd's on my JVC MX-D301T system
I have recently been unable to play cd's on my system. I can insert /load discs into the player but they will not play.
I would appreciate any help. Thank you.
    Scholar:
  • 146 Answers
You can take a dry q-tip and clean off the lens of the laser assy. This is all that a consumer can do. Otherwise take it to a repair shop.
Posted on Nov 20, 2008
Cd inserted in cd player no disc
The problem is in the laser pickup assembly, overtime the laser becomes weak until it will no longer read the disc, it is far cheaper to replace the stereo than have the old unit repaired.
May 01, 2012 | JVC MX-GT80 Shelf System
Can i attach my phone to my jvc mx-D301t in anyway?
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input on ANY audio device EXCEPT one labeled "Phono".
Aug 14, 2011 | JVC MX-D301T Shelf System
I have an old JVC stereo model number MX-D301T. There are two issues with my stereo. First, the volume wheel has stopped working. It is stuck on the highest volume setting and does not change when the...
The volume is probably controlled by an IC that does all the work. It most likely has failed. It's unlikely that the wheel is the cause of the trouble, unless it has broken leaving the circuit fully open. But I think that unlikely.
If the unit has not been used for sometime then the second fault will probably due to the belts turning to goo!
Oct 01, 2017 | JVC MX-D301T Shelf System
How do i set the clock on my jvc mx-d301t
Hi, I just set the time on my mx-d301t and it goes like this: First you need to put the device to standby mode (red light and the time are showing). Then you take the remote and press first SHIFT button and then CLOCK button (number 1) one after another and the time should start blinking. Next you can set the time by using the SELECT buttons - (number 4) and + (number 5). When the time is right you just need to press SET button (number 8) and the time should stop blinking. There you go, the time is set. -amigo
Jan 25, 2011 | JVC MX-D301T Shelf System
Have a jvc MX-J500. (purchased as a previously owned unit) When a cd is inserted in any of the three trays it just says "no Disc". Radio works as well as the cassette player. System was dusty but appeared...
You could try a CD lens cleaning disc which will clean any dust off the laser lens. But it is possible the laser power can be low if it is an old player. this will stop the discs being read fence the fault No CD as it cant see the disc. This will mean either a new laser assembly or complete CD deck. Try the cleaning disc first and if that does not work take it to a service centre or just use it as a radio cassette in the garage.
Jul 21, 2010 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
I've had my MX - D301T for about 12 years. We
There are rubber drive parts used in the cassette mechanism, and over time they wear out. Infrequent use can hasten the rubber failure (similar to how a car's tires can go bad if a car sits idle for a long time). An overhaul by a stereo service shop, a good cleaning and replacement of the affected parts, will bring it back to life.
Feb 18, 2010 | JVC MX-D301T Shelf System
Error message No Disc
Unit has bad disk t-table motor
May 06, 2008 | JVC MX-J200 CD Shelf System
Disc won't play
Silmilar problem on a MX-D501T
At times the unit fails to recognise the music CD in the tray, or recognises its presence and shows tracks & time play on screen but doesn't initiate playing. The fault is erratic. Pushing 'play' on the remote doesn't initiate either.
Is this a faulty head or 'dry joints' somwhere?
Dec 09, 2007 | JVC MX-D301T Shelf System
JVC MX-KB30
Have it first cleaned by a cd disc cleaner or if you are familiar with cleaning the lens manually im sure that will work...or try inserting an original cd's,if it works with that find the solution to the settings of your device...
Sep 22, 2007 | JVC MX-KB30 CD Shelf System
JVC MX-D301T Shelf System Logo
328 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
