Question about Xerox Phaser 8200 Laser Printer
Error 07.003.45 I installed two new bulbs in my Xerox 8200, thanks to great help here. Now i get the Error: 07.003.45 along with a paper jam. Any ideas?
    President:
  • 2,072 Answers
Yeah. What most likely has happened is that the switch actuator in the registration transport you removed snapped. It is on that metal transport you remove on the upper part of the machine.
The actuator is located on the left side of that transport. It has a black plastic shaft on it about 6 or so inches long. The actuator sticks up through an opening . There is a flag that is about a half an inch high and maybe 1/4 of an inch deep that has snapped off. That is the most likely cause.
OTHER things to look at are this. 1 Did you remember to plug the electromechanical clutch back in? 2, Did you get the clutch mounted correctly, there is a fork on the clutch that has to be slipped through a metal tab to be sure the clutch does not spin when it is engaged. # Did you get the black drive belt back on behind the clutch?
Before removing that transoort again and seeing if that actuator is broken, remove the left side cover and see if any of the issues with the clutch are the problem. Then look at the actuator.
Posted on Nov 21, 2008
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Phaser 8200, paper will not feed. It picks up, but will not go through and then says paper jam. I have taken everything apart to the light bulbs and can find no paper jam.
you need to check what are called sensor flags. These are sensor the detect where the edges of the paper are. These can be broken off or loose, or dirty. You can google image of these for a better ideal.
Aug 09, 2009 | Xerox Phaser 8200 Laser Printer
Xerox 8200 printer error 15.004.45. How do I
If this is your first rodeo, contact www.inktechnologies.com. They can walk you through it and provide the parts.
Jun 28, 2009 | Xerox Phaser 8200 Laser Printer
Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
May 21, 2009 | Xerox Phaser 8200 Laser Printer
Error messge xerox Pahser 8200 09.007.42:11683
The yellow ink sticks are jammed.
Open the ink loader and ensure that the yellow ink sticks are able to slide in the ink loading chute. Remove any broken of partial ink sticks.
Dec 07, 2008 | Xerox Phaser 8200 Laser Printer
XEROX 8200 PAPER JAMMING
SOund more to me like you have worn out feed wheels. They are slipping when trying to feed, therefore you get a paper jam indication, but no paper has been fed. Check the feed roller texture. If it is slick replace the roller.
I will state that first. You could have a sticking sensor, but that is less likely if you say it feeds paper.
The second most likely problem is the paper feed or paper registration clutch failing. Those are electromechanical clutches that are located on the loerf front section of the frame. You would need to remove the left side cover ( looking from the front). The clutches are round and silver, about an inch and a half thick with black gears on them. If the clutch faces are slipping, the rolllers will not drive and result in a jam.
The more I think about what your describing, the more I believe one of your clutches is bad.
Sep 26, 2008 | Xerox Phaser 8200 Laser Printer
Paper Jam - Xerox 8200 Phaser Printer
I was same problem and I repaired. In to machine, look of preheat switch ( behind of black roller ). I found piece of paper under the switch. Good luck :)
Jun 02, 2008 | Xerox Phaser 8200 Laser Printer
Error phaser 8200
This error message is related to the drum heater malfunctioning. It is basically 4 small halogen bulbs that warm up the image drum. Sometimes one or two of the bulbs will blow causing this error. The part # is 650-4228-00 Drum/Paper Heater assy. It is not extremely difficult to change, however you need torx bit screwdrivers to remove the components, also there is a very delicate paper sensor that needs to be removed, so you may want to have a technician replace it.
Hope this helps!
May 20, 2008 | Xerox 8200/DP Thermal Printer
My printer only jams when printing multiple pages
Is there a specific code you are getting when the machine stops?
It can be a few things, one would be a 3 letter number code, the other a 8 digit number listed as xx,xxx.xxx.
That would help greatly in determining your problem.
May 13, 2008 | Xerox 8200/DP Thermal Printer
Xerox Phaser 8200 Laser Printer Logo
64 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
