Question about Linksys Wireless-G WRT54GS Router (e125894)
Problems hooking up a Linksys wireless router
Can not hook up a wireless router to the cable modem. Keep getting the following error message:
Not possible to disable the connection at this time. Connection may be using one or more protocols that do not support plug and play or it may have been initiated by another iser of the sytem.
I have no idea what this means. There are no other users; this is my home computer.
Thank you
    Genius:
  • 1,269 Answers
Please disconnect the USB cable that connected from the modem going to your PC. Now connect the ethernet from your cable modem to the Internet port of your router. Run the setup CD, that should guide you and will make you up and running connected to the router.
Posted on Nov 21, 2008
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
Trying to hook up a linksys wireless-g 2.4 ghz to a dsl modem for wireless how do i do that
Connect the DSL modem with a LAN cable to the WAN port on the Linksys wireless router. If you have not already configured the Linksys wireless settings, this is the next step.
To configure the wireless router and prevent unauthorized access to your wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Oct 28, 2010 | Computers & Internet
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys WRT160N Wireless Router
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
I have hooked up the wires correctly and I keep getting an error message stating that I have not hooked it up correctly.
well to hook up a wifi router, u connect the cat 5 cable from the internet port on the router to the cable modem and u coonect your computer to any of the open ports.
Sep 21, 2009 | Linksys Wireless-G WRT54GS Router...
Trouble setting up router
Make sure it is not a cross-over cable, and unplug the Ethernet cord at both ends and then re-connect. Also try a different cord. If you are doing this wireless I would recommend you using an Ethernet cord. You could also push in the little reset button on the back of the router for 45 seconds and then unplug the router then plug it back in and start over with the CD.
Jun 26, 2009 | Linksys WRT160N Wireless Router
Router not hooked up properly
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed.
then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
How to change Linksys wireless router?
When you get cable internet, the cable company provides you with a modem (usually). From the cable modem you can hook up the Linksys router with an ethernet cable and it will work just fine. Hook the router up to the desktop or laptop with another ethernet cable if you need to make changes to the router security or whatever. The router address is generally 192.168.1.1. YOu can type that address right into the internet address and you router page shoud show up. If you have been using the Linksys router with the phone line all you need is to connect it to the cable modem to work. An ethernet cable is like a telephone line with a fatter connecter.
Nov 29, 2008 | Linksys Wireless-G WRT54G Router
Trying to install second linksys wireless router and an error message is coming up
What is the error message?
Also please tell me exactly how you have everything physically setup.
for example
Modem- ethernet cable- router 1 's wan(internet) port- ethernet cable(which port 1-4?)- router 2's wan(internet) port
and if any othe computers are hooked up to it through ethernet cables, please include that.
Apr 17, 2008 | Computers & Internet
Linksys Wireless-G WRT54GS Router (e125894) Logo
98 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
