Question about Adams Coolrunner Jogging Stroller TB3040 Jogger
Problem I have a single stroller and it pulls one way if I adjust it just pulls the other way. Just won't go straight
0 characters
1 Points
Stroller stuck and can't be folded
I had the same problem with mine. What I had to do was lift the Adjuster for the backrest while doing that pull the back rest all the way down ( like if baby was laying straight not at a angle) and then pull the two hand hooks and then fold down.
Mar 17, 2013 | Baby Strollers
How can I stop my P&T front wheel from wobbling all over the place. It doesn't give a smooth ride?
I don't think that's possible. the front wheel usually doesn't have a lot of pressure on it, so its a little bit in the air some times, and that's what makes the wheel wobbling.
try to put something heavy in the front of the stroller, that could smooth it out a little
Mar 03, 2011 | Phil & Teds E3 Jogger
My phil&teds sports stroller adjustable
Have you tried giving it a firm wiggle up and down? Try pressing the buttons in firmly to make sure they are completely depressed. Try to pivot the handlebar while keeping the buttons firmly pushed in.
If both buttons are pressed in and there is no movement up or down in the handlebar you may have to replace it. I am not aware of a way to get to the mechanism.
If the stroller is less than a year old it may be covered under their warranty policy. You can find more info at
Feb 27, 2010 | Baby Strollers
Hi I have the Schwinn M3 Jog Stroller and it has a slight pull to the right. Can you tell me how to fix it?
Is the each wheel on straight and tight?
If so, spin each wheel with the tire facing you and see if you notice any wobbling or warping effect. It's possible that either the axle of the wheel is bent or the spoke/rim is not true.
If the wheels have spoke nipples that can be adjusted, you may need to take it to a bicycle shop to see if they can true the wheel or otherwise it'll need to be replaced unfortunately.
Nov 07, 2009 | InSTEP Schwinn Titanium M3 Jogger Stroller
How to fold stroller
i have both the double and single dreamer design stroller and on both - there is a black pull thingie ... if you put your hands on the handbar and then follow down the frame (along the back side of the seat). You will feel it - as it is kinda hard to see. Once you pull this on both sides, push down on the handbar - towards the ground. The stroller will then fold down and in half.
Aug 18, 2009 | Dreamer Design Ditto Manhattan Twin Seat...
How do i adjust the shoulder straps to a bigger size
here you go. We had the same problem :-)
May 23, 2009 | Mountain Buggy Urban Single Stroller
How to fold a beby trend expedition single
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Love the Venezia stroller but can't figure out how lower back res
On the back of the backrest there is a **** in the fabric with a metal handle/lever. Pull up on this lever to adjust the backrest in numerous positions, including laying flat.
Jan 12, 2009 | Peg Perego Venezia Single MT Blu Moon...
Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Mar 30, 2007 | Baby Trend Expedition LE Jogger
Adams Coolrunner Jogging Stroller TB3040 Jogger Logo
20 people viewed this question
Top Adams Baby Strollers Experts
Stephen Faulkner
Stephen Faulkner
Jennifer Rock
Jennifer Rock
Are you an Adams Baby Stroller Expert? Answer questions, earn points and help others
