Question about Electrolux EL5020 Vacuum
Brushes not turning Electrolux Intensity (EL5020)
My daughter's roommate used her Electrolux Intensity and afterwards it was making a really loud noise.  I don't know what happened while she was using it.  I looked under it and the brush seems to be scraping the inside of the shell when it turns.  The noise is only when the brush is turning.  I took it apart to see if anything was stuck but nothing was there.  After putting it back together, the brush does not turn at all.  I checked and it is back in correctly and the belt is on it.  Can you help?
  • Anonymous Mar 24, 2014
    I am looking for a substitute brush part 63322, for an Electrolux Intensity EL5020.
It needs a new brush they get stripped out by hair and stuff
Posted on Mar 08, 2011
Intensity vacuum really loud
Loud vacuum is usually a broken fan which requires pulling motor.
Jan 26, 2014 | Electrolux Vacuums
Makes heavy vibration noise when turned on for carpet and belt is good
Check the brush roll and the end caps to insure the brush roll is spinning freely. If there is wear or damage to the brush roll it can cause it to be out of balance and vibrate
Jan 12, 2014 | Electrolux EL5020 Vacuum
The brushes wont turn
Have you checked the belt, get back to me if this is not the issue. thanks.
Mar 08, 2011 | Electrolux EL5020 Vacuum
When you plug in vacuum it blows fuse in house fusebox
I have the same problem and I don't know what to do?
anybody?
Aug 12, 2010 | Electrolux EL5020 Vacuum
The belts not turning
for sure the fan is broken that was the noise has to be replaced if you didn't feel any burning smell the motor still good also the first thing should be replace the belt for a new one the old one might be worn
Jun 11, 2010 | Electrolux EL5020 Vacuum
No power
use a t6, or t4 screwdriver,
b4 u go on plz check the fuse of ur machine, or the power rating of it.
or check for the earthing.
Jul 16, 2009 | Electrolux EL5020 Vacuum
Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Jul 07, 2009 | Vacuums
Change cord on electrolux EL5020
In order to get to the cord that is disconnected you need to remove the screws that hold on the frame(the red shell). You will need to remove the "fenders" that are near the wheels. In order to remove the fenders get a flat tip screwdriver and pry up on the front part of the fender, there are three clips holding the left one on and two holding the fender near the cord. You will need to remove the left wheel (the wheel farthest from the cord). After you remove all the exterior screws and the four screws under the brissels the shell should be able to be removed. Next you will need to pull the cord all the way out and there will be a clear clip, use a flat tip screwdriver and release the clip in order to remove the clear piece that holds the power cord electrical ends. Reattach the clips of the power cord and be sure when you put the clear piece back in that the two contacts are not bending. You will need to use a screwdriver to guide the electrical clips back into place. I didn't count the screws there is a lot of them. I hope this helps you
Sep 20, 2008 | Electrolux EL5020 Vacuum
Electrolux EL5020 Vacuum Logo
402 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
