Question about LG WD-1280FHD Front Load Washer
Washing machine keeps stopping mid cycle
The washing machine (5 years old) has started showing the error code DE or could be OE (hard to tell). I have drained the machine, emptied the filter (there were coins in it) and all seemed well but the machine got halfway through a programme again and refused to move
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Posted on Jan 07, 2009
Why does my 5 year old machine keep stopping mid-cycle?
Check the door sensor and clean it. Or one or more(i believe there are three) of your tub sensors may be bad.
Sep 11, 2015 | Washing Machines
My washing machine stops mid wash and on d LCD display it has the letters OE sometimes the machine doesn't spin an if t does the cycle it doesn't let the fabric conditioner go n the was
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service. Clear the filter located on the bottom left on the face of the machine. You will find a access panel located there that you need to open. richroth_61.gif Happy Holidays The FixYa Team
Dec 19, 2010 | LG Washing Machines
I have an lg front loader washing machine...it keeps stopping mid cycle and gives a troubleshoot code of oe...i cant find my owners manual and the lg site is awful....can you help me?
OE is drain error..Most likely problem is partially blocked pump filter...This is accessed via the small door at floor level...Unscrew the pump cover and clear the filter..Any water in the machine will flow from the pump cover...Empty the machine first...Leaning it back can help....Good luck....Nomess
May 14, 2010 | Washing Machines
Shows OE error. Won't spin
if its only 6ths old call out the manufactures.
Sep 28, 2009 | LG WM-2277HW Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
LG WD-1280FHD Front Load Washer Logo
709 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
