Home | Sony | KV-27S20 27" TV | Tv screen Faulty
Sony KV-27S20 27" TV
Problem for Sony KV-27S20 27" TV
Tv screen Faulty
By josexto on Jan 01, 2007
I have a sony triniton TV set which has operated for about four years without any problem but one day, as the tv was on, the screen went black showing nothing and some little smoke was seen coming from behind it. What could be the problem or advise me on which probable spares that could be blown. Thanks alot. Josexto.
Same Problem
Dec 31, 2007
-   I saw the tip previus posted with the problem of the Sony TV KV-27S20 has a black screen but audio OK. It suggested to veryfy the resistor R587 but i didn't find it. Could some one give me a little help?-   blessman
Best Solution
posted on Jan 01, 2007
Helpful)
henlopen
Rank: Wiz
Rating: 84%, 649 votes
It's always a bad sign when the magic blue smoke is released from inside the TV set. I would suspect a defective capicator has blown its' top. When the screen went black, did you lose audio also? If you still have audio, it's possible that resistor R587 Opened up which would smoke, (1.5k 1/4 W) And D518 Shorted (Nte558) If you lost audio as well, then it could be a shorted Vertical IC pack. If you're not up to testing and replacing components, the set will need to see a repair shop.
Was this helpful?
Yes
No
Popular Solutions for Sony KV-27S20 27" TV
Questions and Unsolved Problems for Sony KV-27S20 27" TV
Do you recommend Sony KV-27S20 27" TV?
Answer
Answer
Sony WEGA tube 34" 4.5 years old. The picture hue is all green/yellow/blue - no red. When I... (More)
Answer
i have a hitachi 36 tube type tv that the picture is slowing geeting darker. even if i turn the... (More)
Answer
have a 42' tv and i can hear the pictrue but cant see it
Answer
I don't have remote control. How do I use capture (subtitle) function for deaf ?
Answer
I have a 32" (?) Sony TV that is 12 years old. It is a floor model that is incased in wood with... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KV-27S20 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 1476
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
