Bosch Axxis WTA 3510 Electric Dryer Logo
Posted on Nov 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rat in dryer vent
A wounded rat (bleeding from an encounter with a trap) escaped through a hole in the vent duct. The trail of blood indicates that the rat went into the dryer but I can't see anything through the vent apertures. How is the best way to insure that the rat didn't crawl into the dryer and die. Do I need to dis-assemble the whole unit? If so, where can I get an exploded diagram of the appliance so I can take it apart? Bosch Axxis 3510.............jerry
Justin Duby
Level 2:
  • Expert 370 Answers
  • Posted on Nov 21, 2008
Justin Duby
Expert
Level 2:
Answers
370
Questions
Helped
166355
Points
897
You can most likely fet a diagram on sears.com. Go to the parts section and put in your model number and it will let you access diagrams.
1helpful
Could the error code AD and flashing lights on frigidare front loading dryer be caused by rodents? It stops drying.. I believe I have rats but cannot confirm if they are in the laundry room yet.
With a few exceptions rats don't mindlessly chew if there is proper food around; they can be crafty rascals and can drag found food to an eating place where their droppings will be found. I am not saying rats never cause such damage but on the other hand mice will attempt to make a meal from anything and leave a trail of their "business" almost constantly. A mouse can get through what we would say are impossibly small holes and gaps; a rat can't.
A friend stayed a few nights on a camp site near a farm. The other campers except for my friend all experienced rat trouble - she put food out for them and they left her alone. With few exceptions rats are intelligent and relatively sensible and mice are mindless vandals by comparison.
Aug 20, 2018 • Dryers
2answers
How can I know if there are rats in my house?
Put out sticky rat traps to see what they touch. The other kind of rat traps might accidentally catch a child's fingers, but the sticky kind won't do any serious harm, and might succeed in catching a rat.
Many different brands available at Walmart and online.
https://www.walmart.com/ip/Catchmaster-Heavy-Duty-Baited-Rat-Glue-Traps-2-ct/15723807
2answers
How can I kill a very smart rat living in my wall?
Watch and see when the rat goes for food. Then set out the food and watch so when it comes out shoot it with a BB gun.
Jan 04, 2017 • Rodents
Hello I have a Indesit tumble dryer that works but keeps flooding the kitchen floor? Model number IDC 85s Help!
Moister in the dryer:
This means that the moist air is not escaping correctly and that is why it is taking so long to dry your clothes - if they dry at all.
a good start at cleaning out lint blocked areas, I suggest go to the back of the dryer and take off the vent pipe or hose and check things out with a flashlight. Clean out all the lint and dust you can, even use a vacuum cleaner on it. Make sure the vent pipe is completely clear of any obstructions.Non-rigid ventshas much worse air flow than smooth piping, so you might want to upgrade tosmooth piping.
Once you have all the lint and dust cleaned out of the dryer, go to where the dryer vents outside. Again, clean the area thoroughly. There is usually a trap door that opens when the dryer air is on and closes when it is not operating. It should be completely clear of lint and opening smoothly.
Also, look into the exhaust area on the dryer carefully to see if there is a hole or gap in the dryer's internal air ducting. Without the vent pipe connected and with no clothes in the dryer, start it and let if run for a few seconds and make sure there is strong air flow from the exhaust port. You should feel it strongly on your hand.
Re-connect the vent pipe and start the dryer again. Feel all around the bottom to see if any air is blowing out from under the bottom. This would indicate there is a break or gap in the dryer's internal ducting. If you do feel air, you will need to call a service technician to see if it can be repaired. If your dryer is very old, there could be a rust hole in the duct.
In conclusion Cause ·Poor venting is a common reason why water might leak into a clothes dryer. Since the dryer works to expel moisture, it is important that the dryer's vents are properly installed so that the humidity can escape.
Effect ·If the humidity in the dryer is trapped, it will eventually turn to water. This will lead to poor drying results or longer drying times, depending on the amount of leakage.
Prevention/Solution ·Faulty dryer venting can be prevented by making sure that the humidity is directed outdoors. Also, vents should be cleaned of lint and other debris before each load so that water can readily escape. Taking these precautions can ensure that the moisture will meet dry, open air.
Read more :http://www.ehow.com/facts_7167266_would-water-dryer_.html
1helpful
Why does my condensed tumble dryer leak water when drying?
Why Would Find Water in My Dryer eHow
Apr 26, 2016 • Dryers
What is causing water leakage at the end of dryer program when it goes into cool?
Mar 29, 2016 • Dryers
1helpful
May tag Neptune dryer forming moisture inside tub
Oct 10, 2014 • Dryers
6helpful
5answers
Animal ripping up car in garage.
CLOSE THE WINDOWS!!!!!!!CATS LOVE DOING THIS SORT OF ****
Top Bosch Dryers Experts
vince
NOEL
NOEL
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
