I WOULD LIKE A CIRERETTE LIGHTER AND WALL CHARGER FOR A MIDLAND 75/779 CB RADIO ! WHERE CAN I GET A GOOD SET
SOURCE: midland 75-785
Given the fact that when you key up the mic you should not hear any thing because the receiver section is "turned off" (no antenna and the speaker is muted). This would seem to indicate that the switch the headset controls which allow the change over from RX to Tx is bad or that the circuit in the CB unit which the head set plugs into is having a problem. Do you hear the same flutter without the headset? Try to get another headset or test one out just to see if the problem is eliminated by using a known good headset.
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
SOURCE: midland cb model 13-895
Hi Frank, It sounds to me like you may have a bad dectector diode. Other possibilities are cold solder joints in the stand up boards in the IF section. Good Luck
Ed
NC Electronic
Mills, Wyoming
SOURCE: wiring a midland 78/999 cb radio microphone
Pin 1 = white
Pin 2 = shield
Pin 3 = black
Pin 4 = red
SOURCE: Midland alan 42 multi CB Radio
The user manual can be found in PDF form here: http://www.alan-uk.com/cb/manuals/42%20multi%20manual.pdf
