Question about Grohe 27.217.EN0 Rainshower 6" Ceiling Shower Arm - Infinity Brushed Nickel
The weight of the arm and rain head is too heavy for fixing
It seems like the weight of the arm and rain shower plate will be far to heavy for the backplate elbow I've installed behind the tiles. how am I going to fit these now?
  • pjstjs2002 Apr 21, 2009
    Instruction call for caution when installing a grohe rain shower head in a shower with sheet rock (blue board) wall.The weight of the head is about six pounds. Is there any easy method for reinforcement without tearing down walls or installing and getting leaks because of the weight.
  • 132 Answers
Can you at all shorten the length of the arm to make the head lighter or can you do the adjustment near the tiles up tighter apart from this attach unsightly bracket from the head back to the wall at worst mate start pulling tiles off ouch ! wish i could more help glenn..
Posted on Nov 23, 2008
Seem to have water leaking under shower into storage competition ment, tried caulking only happens when shower is on and someone is in it very frustrating
Very often happens for a number of reasons
Bad caulking around the shower base and the base drops with the weight of the occupant allowing water past the caulking.
Crack and bad seal on a wall tile.
A split in the base itself which opens up with weight and you can't see with the base empty.
A leak in the pipes behind the wall from the mixer unit to the shower head.
Split pipes or fitting to the drain.
Best way is a full tear down, refurbishment and start anew :>)
Jul 10, 2016 | Home
Ok we'll I'm trying right now to unscrew my old ball end shower arm and cannot for the life of me get it to unscrew and can't understand why?? I'm not too sure how long it's been there but it won't even...
use multi grips and unscrew the shower arm from the wall and attach your new arm in its place
use use multi grips on the knurled section that holds the ball ( shower head ) on and fix your new shower head in its place finger tight
Jun 07, 2017 | Cars & Trucks
Where is the escucheon located
this is the plate behind the handle or it is the plate that is on the shower head arm itself its the little circle plate that is againts the wall to hide the hole
Jan 20, 2013 | Union Pegasus F1228100PBV Series 5000...
Hello, I am putting in a grohe 35016 rough in valve. My shower has cold/hot 1/2" pex line coming in and i need to have one line going up into the ceiling for a rain shower head and another line going...
Hook the cold line up to right side and hot to left. Run line to wall shower off the top and use two 90 degree elbows with a short length of pipe turned slightly to the side of the line to wall shower. Run pipe up to ceiling height then 90 over and down to location you want forrain shower head. Hope I made this clear as I know sometimes I don't explain things well. Thank you.
Feb 04, 2011 | Home
I've attached the shower head as tightly as I can but water backs up and sprays upward and outward with very little coming out as spray. Seems that a washer is needed but note came with my...
There should bea rubber gasket/washer that goes between threads on shower arm and inside of shower head. If this is a new shower head I would return it to place of purchace for exchange. If not you should be able to get the waher seperatly. If not you can get a cheap shower head and use the gasket from it. I also would recommend that you use several wraps of teflon pipe joint tape on shower arm and tighten snugly.I hop this helps you. Thank you a have a good year
Jan 02, 2011 | Water Pik Shower Head
The device the sprayes water from the shower head has broken. The shower head does not unscrew for the shower arm. The shower arm is attached behind the tiled wall. How do I remove the shower arm and...
The shower arm should be screwed into an elbow inside the wall. Unscrew the shower arm by putting your pipe wrench on the arm and unscrewing in a counter clockwise direction ( lefty loosey, righty tighty ) . Measure the length of the arm going inside the wall and make sure your replacement has enough length to reach. Teflon tape the inside end ( the end going in the wall ) and wrap a rag around the new arm, then screw into the elbow going clock wise , stopping when it starts getting tight and with the bend facing downward. Install shower head.
Nov 20, 2010 | Price Pfister Home
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
Could i get a clear drawn instruction for putting the together the delta monitor 1800 series showerhead?The showerhead doesnt seem to fit on to the pivoting ball. Thankyou
My first instinct from your description is that the arm that comes out the wall to put shower head on has a rounded ball as a part of it with no threads on it. If so, it needs to be replaced with a standard shower arm with threads on both ends to acccomodate your new head.
May 19, 2010 | Delta RP28602-CB Replacement Ultimate...
Grohe 27.217.EN0 Rainshower 6" Ceiling Shower Arm - Infinity Brushed Nickel Logo
469 people viewed this question
Top Grohe Home Experts
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
