Question about Nextar X3-02 GPS Receiver
Need battery for the Nextar GPS model x3-02
Need replacement battery for above model
  • Anonymous Mar 24, 2014
    My card is not in my GPS. Haven't used it for awhile so battery is in need of charging which I'm trying to do. How do I get a new card?
    Problem Solver:
  • 6 Answers
Actually, it's quite easy to replace:
i. Take off four screws at the back.
ii. Between the body and the front bezel, insert a utility knife. The bezel is fixed to the body with tabs. I started from the left hand side from front. The tab is in the center. Careful not to scratch the bezel or the body. Once one tab is open, you can slide the knife or whatever tool you're using to open the rest. Be careful not to scratch.
iii. Once the front bezel comes off, you'll see that the touchscreen is held to the bezel with the help of four tabs. take the touchscreen off.
iv. Next, take the ribbon cable off from behind the screen. You'll have to flip the flap holding the cable open.
v. The screen is held to the main board with the help of a tape. Don't take it off. Take off three smaller screws which fasten the circuit board to the back body.
vi. Take the antenna off. It's quite easy. It's the same connector that is used for Blue-tooth or wireless antenna on laptops. It'll just flip off.
vii. Next, take the board off from the back plastic body. The circuit board will still be held to the back by two connectors, one (two wire, smaller one) connecting the circuit board to the speaker, and another (larger one, four wires) connecting it to the battery. Both the battery and the speaker are for now fixed to the back plastic body.
viii. Once you've done that, the battery is exposed. Take the battery off (held by two tapes, and some double sided sticky tape to the back body).
The battery is 35mmx55mmx5mm. Buy any 3.7v battery from ebay. That'll cost you about $10, including shipping. The only problem is that on ebay, you might not be able to buy the same connector. Most of the batteries that you get from there also have protection circuitry to protect against overcharging etc. So you'll only have to replace the connectory. For this, take apart the battery from top. Just peel off the green tape. That will expost the connections. Solder them off, and replace the entire chord on the new battery.
Sorry, I'm too depressed right now on account of loosing my job :-) Otherwise, I'd have included pics too. But I guess if you're not afraid to do DIY projects, you should be able to change the battery yourself. Quite easy.
-pkrobot
Posted on Dec 26, 2008
  • PKROBOT Dec 26, 2008
    I had an old Palm Tungsten E with cracked screen. Took the battery out to replace it in x3-02. The battery size is almost the same, i.e. 35mmx55mmx4mm (thinner by a couple of mm). The rating is 1100mha. Had to peel the tape off from both the batteries, which exposed the soldered leads. Took the leads from Tungsten battery, and replaced it with x3-02 battery leads. Working OK, but I noticed one thing. The battery life was no better than what x3-02 had before. I might look into getting a larger capacity chargable battery. Another thing was that I had to fidget the battery to fit, since tungsten battery had tape on both ends, which made it somewhat longer. Not a problem, since the ends were just tape, so flexible. Also, originally, I mentioned that the x3-02 battery is 5mm thick. Actually, it's 6mm thick, so you can go for a higher capacity battery. This guy's a battery guzzler, so might as well. The tungsten battery is available on ebay for less than $10, including shipping. You'll need a soldering iron for this project.
My Nextar opened pretty much the same way. Mine was very tightly bound together with that sticky tape. It was a real delicate bit of finger ballet and cussing to get it open. Then I tried to remove the #$&X#!! speaker connector from the circuit board to avoid stressing the wires. The thing was held on so tightly that I tore one of the wires from the connector. Oh great. Nice. More micro-soldering to do. The battery was also bound down to the circuit board quite tightly with more of that insipid tape action. I really had to pry and fiddle with it to get it to peel off. I head to my local battery store tomorrow and (hopefully) find a suitable replacement battery. Based on what I'm seeing, I very highly doubt that I can find the exact factory replacement, and quite frankly I don't want another Chinese made battery anyway as it has been my experience that they don't make diddly piddle squat for batteries in China- so I'm hoping for a Japanese or SOMETHING else.
Posted on Aug 20, 2009
Instruction to replace with iPod photo battery.
I successfully used iPod battery (that fits 4th gen iPod or photo iPod) to replace the dead one inside my Nextar X3 GPS device. Since iPod is a very popular device, there are plenty of these batteries sold on ebay and amazon. I bought mine from accstation seller for $6.29 with free shipping. This battery is rated at 1200mAh, and is slightly smaller than the one inside the Nextar: 35mmx50mmx3.5mm vs 35mmx55mmx5mm. The iPod battery comes with some tools that makes it easy to pry off the LCD screen from the Nextar's body.
To open up the case, remove 4 screws on the case, pry off the LCD screen from the case. Inside the body, there are several pieces of tapes that connect various things together, feel free to remove them as they can be re-attached. Remove the 3 screws on the circuit board and pry it off the case. Unplug the speaker connector and the battery connector. The battery is stuck to the case with a very strong adhesive tape. Put a thin knife (or envelope opener) between the battery and the case, and twist it so get the battery out.
I didn't need to solder anything. Just had to strip the wires and twist them together. I cut off the 3-hole connector on the iPhone battery and replaced it with the 4-hole connector on the old Nextar battery. The wiring works as follows: Nextar battery has 2 red (hot) and 2 black wires. The iPod battery has 1 red (hot), 1 black, and 1 white. I just connected the 2 red into the 1 red; 2 black into the 1 black, and left the 1 white alone. I didn't know what this white wire is for, so I didn't use it at all. If anybody knows, please speak up.
If you have never connected wires before, here are some instructions. Use a wire stripper or a sharp blade, cut around the wire about 1/4 inch from the tip. Do this Gently so that the copper inside is won't be cut. Pull off the plastic to show the smaller copper wires inside. Use the blade or knife to scrape gently on the copper wires to remove the thin coating around the tiny small wires inside. To connect two wires together, just twist the copper wires of them together. Then put black tape around the bare wires so that they don't touch and short the circuit.
It works fine and charges fine. The battery doesn't last as long as the original, as it's physically smaller. But it's one of the few that fits inside the case.
Posted on Oct 18, 2009
Need a replacement battery where do I get one this is a q3 nextar gps
batterydepot.com This sight has every battery known to man kind, and can ship it out pretty fast and cheap. Please if this helps , don't for get to rate with the 4 thumbs up, for credit for me and to help others, keep me informed if you would need more assistance. Thanks Mike
Jun 18, 2011 | Nextar Q3 GPS Receiver
Hi, my gps nextar x3i-02 is not turning on, what can I do?
The problem with your nextar is either the battery or the charger is faulty. Either ways you need to test them both then replace the faulty part. That is why the gps receiver is not powering up.
Do not panic when your gps seems to be acting funny, There is no problem without a solution, and if it is beyond repair the solution will simply be that you replace the gps receiver.
Solution:
  1. Test the battery in another gps receiver, to see if it will power it on,
  2. Charge the battery in another gps receiver for about 2 hours with another charger then try to power it on,
  3. If it turns on, then it means the battery is okay and working fine, but if it does not turn on the other gps, then it means the battery is bad and need to be replaced.
Solution:
  1. Test the charger on another gps receiver to see if it will work.
  2. If it does not work then you need to replace it,
  3. But if it works then you do not need to replace it.
After carrying out the test, you will be able to detect the problem and solve it.
Hope this information helped.
Dec 23, 2010 | Nextar X3-02 GPS Receiver
Need new map insert for gps where could I get one?
To update the existing map for your Nextar product, please contact Nextar to find out if any new map information has become available. The products are usually pre-loaded with USA/Canada maps, depending on the model.
OR
Go to Nextar.com and select your model.
Aug 21, 2010 | Nextar Q3 GPS Receiver
Battery doesnt stay charged like it used to ? approx three years old , works ok with charger plugged in
The battery has come to the end of its service life, you will need to replace the battery. Contact Nextar at www.nextar.com for information.
Jun 17, 2010 | Nextar I4-BC GPS Receiver
Need nextar gps update
OR
Dec 05, 2009 | Nextar X3-03 Car GPS Receiver
Need to upgrade the maps on my nextar x3-03
To update the existing map for you Nextar product, please contact Nextar to find out if any new map information has become available. Nextar products are usually pre-loaded with USA/Canada maps, depending on the model. If you need updates
Contact Support
service@nextar.com in USA or GB for new maps
and quote your model number
Jul 23, 2009 | Nextar M3 Car GPS Receiver
My Nextar GPS doesn't hold a charge and I'm not sure how to update my nextar GPS
Your battery most likely has cell dammage, this prevents the battery from holding any acceptable charge. You can take the device to a batteries plus and they might be able to refresh the battery to hold an charge, if under a year, send back to the manufacturer. Since you did not provide a model number there are different ways to update the GPS, here is the company support site.
http://www.nextar.com/frontend/gps_navigation_systems.asp
Jul 20, 2009 | Nextar GPS
Need a battery for a nextar gps model W3G
hi I am rainbow,Our company produce batteries,main about GPS battery,we can chat with each other.my msn is rainbowliu0626@163.com, and my QQ is 36184788.
May 04, 2009 | GPS
Nextar X-11-15302 or P3
A generic 12 volt adapter should work. I replaced mine recently. They usually come with multiple sizes of round ends and can adjust the output voltage. The side of the device will tell you the polarity and the voltage required. If it says something like 5 V but the adapter only has 4.5 V or 6 V, select the closer choice. If they're about equal, select the lower one. It is better to have an under volt than an over volt.
Feb 16, 2009 | Nextar P3 GPS Navigation System
Nextar X3-02 GPS Receiver Logo
2,930 people viewed this question
Top Nextar GPS Experts
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
