Question about Panasonic KX TGA270S Cordless Expansion Handset
I have no dial tone on one line. call my number and it rings
I have a panasonic kx-tga270s, i have no dial tone on both lines on this phone and on my other phone (a panasonic phone system) i have a dial tone on the other line.
when you call my phone it just rings and rings
when i pick up the cordless phone the privacy goes on. there is also an icon on the phone that looks like a clock
  • Anonymous Mar 31, 2014
    i am unable to make or receive calls but line one works
    Problem Solver:
  • 12 Answers
IT IS DUE TO NETWORK FAILURE OF THAT LINE
Posted on Jan 05, 2009
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
How do I program different ring tones for the KX T7220. THere are 6 to choose from I believe.
1 Press program key
2 Dial 99
3 Press line key or intercom key twice
4 Dial 1-8 for tone type
5 Phone will ring with new tone
6 Press store button(autodial)
7 Press program key to end
Dec 07, 2010 | Panasonic KX T7220 Corded Phone
Two phonelines no longer accessible. Using Panasonic KX-T7730 with a Panasonic KX-TES824 system. Lines were working fine and have now disappeared. They don't ring in and I can't ring out on them. ...
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
Oct 09, 2009 | Panasonic KX-T7730 Corded Phone
I have a Panasonic multi talk phone 2 line phone, model KX-TGA270S. Somehow , it shows "ringer off line2" I can't find a way to remove this. What does it mean? Line 2 still rings
I have a Panasonic Multi-talk KX-TG2740 and I need to change the outgoing message. Anyone know how to do this? (There is no "greeting" button as mentioned below).
Thanks!
Sep 07, 2009 | Panasonic Lands Phones
Phone Rings,but cannot answer
if there is no dial tone that means that the connection is not being made when you pick up the phone hence you cannot answer nor can you get a dial tone
the fact that the phone rings indicates that the land line is good so the fault is in the phone itself
Nov 06, 2017 | Panasonic KX-TG5652 Twin Cordless Phone
The speaker on the speaker phone does not work.
CHECK THE SPEAKER LINE IF ANY PROBLEM IS SEE THEN CHANGE THAT LINE
Dec 20, 2008 | Panasonic KX TGA270S Cordless Expansion...
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
CHANGING THE RINGTONE
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
img%20right%20hand.gif The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
Mar 20, 2008 | Panasonic KX-T7730 Corded Phone
No dial tone and "line in use " message
the wire that is used to connect the line to the telephone is not proper...
Mar 02, 2008 | Panasonic KX-TG6071M Cordless Phone
Panasonic KX TGA270S Cordless Expansion Handset Logo
700 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
