Question about Xerox WorkCentre Pro 575 Plain Paper Laser Fax
Xerox workcentre Pro 575 How do I change the time of day setting
I am able to use the menu to get to the date and time mode but can not get past the mode to change the date = only need to change the time of day.
    President:
  • 2,072 Answers
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Posted on Dec 11, 2008
How do you clear the memory when the machine says memory full 100%
You can find your answer at the link below. Just type "memory full" in the search dialog box and it will provide you with the many results and solutions for clearing the error. The message can be the result of many issues, so you may need to perform a few different steps:
http://www.support.xerox.com/support/workcentre-pro-575/support/enus.html
Jun 22, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
What does NGB0 mean on the activity report?
NG is shortcut for "No Good", indicating a problem. "B0" is the fault code for a communication problem, usually caused by an incompatible setting of communication mode G2 or G4 on the remote machine.
Contact the remote operator and ask he set up his machine for EECM or G3 communication mode, then retry.
Jan 06, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
I have a workcentre pro 575 and am receiving the message, "memory full". Nothing will print, and I hope you can tell me how to get the stored memory to print out. Thanks.
You hopefully just need to clear memory, delete phone numbers or delete jobs.
If those don't work the Main Board might be bad 160K72560
Whit
Item, Inc
Aug 17, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
NEED DRUM RESET INSTRUCTIONS
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Jun 24, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Work center Pro 575 will not communicate with PC.
I changed the port address to 3BCh-3BF and set the port to SPP. Rebooted twice and all seems to be working. Noticed the WorkCentre wakes up from Power Save mode on reboot, if this happens then all is working OK.
Dec 06, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Xerox WorkCentre Pro 575 error message
Could be the tab that actuates the top cover switch is broken off.
The process unit is your drum,toner, and developer unit. It sits right under the top cover. Big black removeable cartridge.
Nov 03, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Drum Life Warning Message
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum. Yes No Press [1], then press [Enter]. The screen will display: Completed. Press [Stop] to return to the Standby Mode. These directions were found on the Xerox website, and worked for me.
Dec 28, 2006 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Xerox WorkCentre Pro 575 Plain Paper Laser Fax Logo
1,435 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
