Question about NEC VT465 Multimedia Projector
NEC V465 -Turned on - steady red light - no fan noise - NOTHING?
We replaced the lamp? Tried again, same thing. No fan start up noise. Can you help?
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
SOURCE: Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Posted on Jun 23, 2008
SOURCE: NEC LT30 - Lamp dosen't turn on.
From the manual: To reset the lamp hold down the "HELP" button on the remote for 10 sec and the lamp indicator will turn off. Then start up the projector again.
It worked for me!
Posted on Oct 22, 2008
SOURCE: LAMP not switching on NEC HT410
I had the exact same problem and solved it. After calling NEC tech and getting no help, my son and I decided to:
  • Remove, clean and reset lamp.
  • Completely clean (with compressed air) system.
And it worked. Here's what we did.
  • Removed lamp and cleaned with compressed air (in cans).
  • Used two cans of air to completely remove all internal dust. In our case long over due.
  • Reinstalled lamp and reset meter. (To reset: Turn on machine, wait 2 minutes or so, then hold down the "Help" button right next to the infrared sensor on the front of the machine).
Works fine now! Dont know if it was technical solution but solved it for us! Good Luck!
Posted on May 18, 2009
I bought a new Sony xl5100 lamp. Delicately and accurately replaced the old lamp with the new one. Installed the lamp and housing correctly. Closed the lamp access doors correctly. Turned on TV...red light...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 11, 2014 | Sony (XL-2400) Projector Lamp for...
Samsung DLP fan noise, TV won't power up
Sorry, not a solution. I am here with same question. It has happened just as you said 4 times in the last two years.
Dec 06, 2013 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
When I turn on the TV the green start up light blinks green and the TV comes on with picture and sound for about 2 seconds, then turns itself off and the code light blinks 4 times, pauses then blinks 4...
4 times blinking means Fan stopped, power is not supplied on Fan 1, Fan 2 Fan 3 and at Fan 4. Or Fan connector is not attached securely. Cleaning these fans by using a vacuum cleaner can also solve your problem. Sometimes these fans are clogged by dust.
Oct 24, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
LG RU-44SZ63D turned off while watching, heard click noise
Problem is either you need to replace Lamp or your Lamp Fan is defective. For Lamp Call Mats 1-800-68-1118
May 13, 2010 | LG RU-44SZ51D 44" Rear Projection...
1999 Altima has a buzzing noise that starts when I
you have a short in the headlight wire trace it back and look for cracked or worn wire
Oct 06, 2009 | 1999 Nissan Altima
I have owned a Sony Grand Wega for about 3 years now and for the past few months the TV has been making a very loud noise. I thought the noise was the fan but came to find out it was not the fan and was...
There is a fan beside the lamp chamber in this TV. There should be 4 fans total, and the one beside the lamp chamber might be making some noise. They are all bearingless fans, so the noise should be relatively low-pitched "whirr" if it is the fan. If the noise is more of a buzzing sound, it could be coming from the lamp driver (ballast) or from the lamp itself. Lamps tend to do strange things toward the end of their life.
If you have never changed the lamp, it is about time. They have a 2.5 -3 year life span with average use.
One thing you can try is to turn the TV on from a cold start, and watch inside the vent areas beside the lamp chamber. If you hear the noise before you see the lamp light up, then it is probably a fan. If it starts as soon as you see the lamp light up, it is the lamp or ballast.
Hope this helps you...
Jan 06, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
SAMSUNG DLP BUZZ ONLY WHENBULB IS ON
A friend of mine does warranty work for samsung ,name is chip call him if you need too! 256-778-0300, most of the time when lamp needs replacing set will not play,the fan behind lamp is there to keep lamp cool when playing ,DO NOT touch lamp if you do this will leave fringer print and lamp will burn your inprint on it when hot!!! then you will have to replace lamp ,they are not cheap.replacing lamp is fairly easy, besides i really dont think lamp is your problem,most likely it would be fan making noise.
Jan 18, 2008 | Televison & Video
A terrible sound
It's the lamp. The same exact thing happened to me, my projector started making a loud whinning noise and the picture quality got really dim. At first i thought it was the fan too but after alittle online research i found out that that when the lamp bulb shatters it does this, so i went a got a replacement and it fixed all the problems. :)
Dec 10, 2007 | Optoma MovieTime DV10 Multimedia Projector
Change the lamp/ didnt help, lamp indicator is on
I actually fixed this myself!!!! Same thing, new bulb, fans work, turn on for first 20 seconds or so, see HP splash screen and then it shuts down. Try below....It worked for me.
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jack-
Nov 12, 2007 | HP Digital Projector Vp6120 Multimedia...
NEC VT465 Multimedia Projector Logo
52 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
