Question about Fagor 5HA-196 X Single Oven
Neff B-AP22-7 oven is not working
The hob works, but nothing else does! The clock is just flashing and does not allow me to set the time. When I try to turn the over or grill on, no red light appears above the temperature knob and there is no heat. There is also no main light and the fan doesn't work.
  • Anonymous Jan 23, 2009
    Exact same problem as above just cool air from the over when open.Help?
3 Suggested Answers
protek480
  • 1723 Answers
SOURCE: Need to repair or replace
The clock is not available anymore. You could remove it and thoroughly soak in WD-40 and Then use a light oil on it after it's completely dry.
Posted on Oct 13, 2009
  • 5370 Answers
SOURCE: Hello, My Fagor 5HA-196 X
Did you tried connecting the oven power cord to any other separate power outlet.Connect oven to the outlet, when only oven is connected and no other appliance is connected.------- The power is getting cut for a second .It can be issue with wall electric outlet.Or the oven is not getting exact power/voltage.Or the over power cord is getting short internally.Or the issue with oven power control board timer.Its cutting off every few seconds and this resets the time.--- If this is the case then board is weak and it has to be replaced.----- First try check in other separate power outlet.If that is not helping then get the over voltage and power outlet voltage checked by the tech.If both checked out ok, then get the over power cord checked by meter.If meter shows drop in voltage, then there is cut in between the over power cord wire.------ But if all power cord wires, the electric wall outlet, the voltage, everything checked ok, then its timer control board issue.It has to be replaced.------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
This should help.Thanks.Helpmech.
Posted on Jun 09, 2011
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
RECENTLY MOVED INTO A NEW HOUSE WITH A NEFF DOUBLE OVEN (OLD ONE). THE CLOCK IS FLASHING ALL THE TIME AND NOW THE MAIN OVEN WONT WORK - CAN YOU HELP PLS
Your oven might need to be reset first before it will work again normally.
The most common reset for NEFF double oven is to press and hold down the two arrow buttons while turning the small knob
Try it!
Oct 04, 2010 | Ovens
We had a power cut yesterday and today my neff electric oven just shut down completely. The clock has also stopped working.
if you have power to oven but the clock is not working it sounds like overvoltage has damaged the clock if clock will reset and you can set the time oven will work.
Jun 03, 2010 | Neff B1421 Electric Single Oven
Clock flashing OOO continously
My son came along and managed to get the clock operating once more by just pressing one of the buttons and turning the knob to set the time. Many thanks for your contact. It was much appreciated. I shall know what to do in case this ever happens again.
Regards, Mary Yorkston
Aug 29, 2009 | Neff B1421 Electric Single Oven
Can't adjust the clock on my 1442 Double Oven
Press the left button 4 times, this takes you to the time which is now flashing and can be changed with the right button. once set, leave it and it will just work from there (i.e stop flashing etc)
Apr 01, 2009 | Neff U1721 Double circotherm Electric Oven
OVEN WON'T WORK
all you need to do is reset clock - get your book out and it gives instructions
Sep 25, 2008 | Neff B1641 Single circotherm super...
Neff series 1 oven
press the two arrow buttons in at the same time as turning the pop out knob
Aug 04, 2008 | Neff B1421 Electric Single Oven
Fagor 5HA-196 X Single Oven Logo
1,007 people viewed this question
Top Fagor Ovens Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Bill Boyd
Are you a Fagor Oven Expert? Answer questions, earn points and help others
