Question about Panasonic Audio Players & Recorders
Panasonic cd stereo system sa-en6/cd player does not work/used a disc cleaner/there seems to be no power to the player
SOURCE: My panasonic SA-AK750 hi fi
Tienes que llevarlo a un centro de reparaciones ya que el sistema de cd esta fuera de tiempo por eso no funciona nada.Hasta que no lo pongan a tiempo no va a funcionar.
Posted on Apr 06, 2008
  • 4234 Answers
SOURCE: i have a panasonic cd
This is an indication that the output amp pac(s) have a problem. Expect a parts cost in the range of $25-$45. Add in the local labor rate for the full repair cost.
Dan
Posted on Apr 16, 2008
  • 4234 Answers
SOURCE: I get an error code
This is a protection indication. Either the power amp pac is defective or the power regulator circuit is faulty. In either case you are looking at about $40-$50 in parts plus the local labor rate for the repair.
Dan
Posted on Jul 22, 2008
SOURCE: Hi, I have a Panasonic
Hi, I have the Panasonic SA-EN9, and if you plug your mp3 player (I have and ipod) into the auxiliary socket you should be able to play it by pressing the AUX button on the remote provided.
Hope It Helps :)
Posted on Aug 25, 2008
tvservice306
  • 458 Answers
SOURCE: Panasonic cd stereo system SA-PM31 won't read cd's
replaced TRV UNIT
part no: RAE0157A-V
Posted on Nov 12, 2009
My cd is not being read on my panasonic cd stereo sa-ch64m
A typical symptom is you insert a disc in the player and after a while; the CD tray opens again with the message referring to no disc being in the system. This can be infuriating because you can see that there is a disc, however, the CD / DVD player cannot.
Every time the tray closes, the laser beam fires two long bursts of laser light, and the focusing platform moves up and down attempting to focus the beam. This is the time when it is looking for a disc. If the laser has failed, then it will not be able to detect a CD and therefore the error message appears.
I normally do two things when this happens. I normally clean the lens just in case there is dust on it obstructing the laser path. If cleaning the lens does not solve the problem then I make sure the laser is working. Second Problem can we with your CD. After some time the CD coating gets deteriorate due to atmosphere, this damages the coating of CD/DVD where data is stored..
I hope try Different CD in your player or clean the lens if the problem doesnt solve, use a CD cleaner to clean it...
Oct 30, 2016 | Panasonic Audio Players & Recorders
Panasonic cd stereo sa pm19 The cd reader skips on any cd. I've tried all the lens cleaners. I was told by an electrician that the tracking mechanism for the laser reader needs periodic lubrication so it...
Your Panasonic stereo will have to be disassembled to access the CD drive. REMOVE POWER BEFORE DISASSEMBLY! Be sure to read and heed the warning about exposure to the laser before attempting maintenance. The tracking mechanism may need cleaning before it is lubricated. For lubrication, I have used silicone spray (the kind used to unstick windows) applied to a cotton swab and then applied to the mechanism tracks.
Nov 11, 2013 | Panasonic Audio Players & Recorders
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
229 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
