Question about Maytag MMC5000 Microwave Oven
Coffee Exploded and now unit just hums.
Yesterday I think I pressed a couple to many zeros on the timer and blew up a cup of coffee. I heard a two loud pops, one from the mircowave and one when the circuit breaker tripped. After drying out the inside, I figured I'd let it dry over night before plugging it back in. Now when I plug it in it hums like it is running. However, the lights nor control panel are funtioning. Sounds like a short to me. Is this worth calling in someone to repair it? It is three years old.
  • Maytag Master
  • 9,098 Answers
If it hums like it's trying to run when you just plug it in but you have not pressed any keys to initiate cooking, then that problem is almost certain to be related to the control panel. Probably what happened is the steam got onto the circuit board. You may find that it has a coating of residue which is shorting out the unit. That can usually be cleaned and any damage corrected. We do that sort of repair for 32.50 nationwide. If it is not cleaned within a few weeks, it can corrode connections and make the damage worse. In some cases the keypad is affected but not the board. If either needs to be replaced, both are available. You can part prices by entering your complete model number here: http://tinyurl.com/gv383 It is also possilbe that in addition you have a problem in the high voltage section. At that same site, you can find exploded view diagrams to help you look over the unit to see if there is any damage to the high voltage transformer or the high voltage rectifier diode. Those parts are reference number 5 and 8 respectively on the diagram for model number MMC5000ADB and I suspect they're the same on yours. Be sure it remians unplugged if you open the unit.
Posted on Dec 19, 2006
I have a Jenn air micro wave and I attempted to heat up a cup of coffee in a plastic cup and forgot about it when I smelled something burning I discovered that the cup had melted and the microwave had
Take a lemon and slice it. Put it in a ceramic bowl of water. Set the timer for 10 minutes. Leave for an hour and then wipe the inside with a clean cloth. It will get ride of the smell, if that was your question? It the cup has stuck to the turntable, set microwave for 1 minutes and scrape the cup off with a paint scraper.
Dec 02, 2016 | In Microwave Ovens
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
Jenn air microwave makes zapping sound and won't heat food
Possible bad inverter board (power) and or the Magnetron which does the main heating.
Oct 31, 2012 | Jenn-Air Microwave Ovens
I lost the user manual to my 30 + cup coffee percolator and I need to know the amount of grounds to use when brewing coffee!
Use approx. 1/2 cup of coffee to 10 cups of coffee....so for a full pot use 1-1/2 cups... then adjust to taste..
heatman101
Sep 09, 2011 | Microwave Ovens
I sent you a message yesterday and as of 3:45 today no one has sent me an answer I have kuerig coffee maker and it does not make a full cup of coffee in the mornings what can you do to help me solve this...
Hi.You may try thiis steps.
took the reservoir off,
siphon water from a hose, blow it off
Maybe that is what has happened in
all of these instances
and getting the air bubble out gives us
a full cup of coffee.Hope this helps.
Jun 21, 2011 | Microwave Ovens
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
How to program my Hamilton beach Coffee Maker,49464 To make coffee in the am before I get up.
12 Cup Programmable Coffee Maker 49464 could help you to operate your Hamilton Beach Coffee Maker. Anyway, if you are looking for a best coffee maker that can extract a perfect cup of coffee, allbestcoffeemakers.com is a great choice. Hope it helps you!
Nov 30, 2010 | Hamilton Beach Microwave Ovens
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Sep 07, 2010 | Microwave Ovens
Maytag MMC5000 Microwave Oven Logo
61 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
