Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox not cooling completely
I was just getting ready to chuck the thing and I found you...please forward a copy of the service manual or let me know what I might be able to do to get the machine cooling completely again. Thanks
  • Anonymous Nov 24, 2008
    COOLING SYSTEM COMPLETELY DOES NOT WORK.
It most likely needs freon added. You can probably contact your local Air conditioning company and they will charge you for a service call and what little freon it might need.
Posted on Nov 24, 2008
I have a SkyBox vending machine. It has stopped completely cooling the drinks. The get a bit cool, but don't get cold. I suspect that it is out of freon. Is this somehting I can fix myself or is there...
You will definitely need a professionals help here because if the freon/refrigerant has leaked out then there is a leak that needs to be found and repaired. Then the system must be dried completely before being recharged and this takes special tools and knowledge. Definitely a techs job. good luck!
Jul 20, 2011 | Maytag Skybox Beverage Vendor
Skybox service manual
go to this web address for the complete diagrama and parts list
http://www.appliancepartspros.com/partseach/mode.aspx?model id=5170483
Dec 02, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
SkyBox Manual
if its not cooling -- is it about 2-3 years old -- the relay overload switch had gone bad
its mounted on the side of the compressor behind the small black cover
go to appliancezone.com
part # 4387835
cost $ 26.00
Nov 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
MAYTAG SKYBOX REPAIR MANUAL
http://kitchen.manualsonline.com/manuals/mfg/maytag/maytag_skybox_by_maytag_personal_beverage_vendor.html
Here is a site that has the manual for this. Good luck! Mine was a piece of ****! Had to have it repaired twice because ice builds up on the motor and THEN the compressor went out. Most refrigerators have a 5 year waranty on the compressor but not these things, its a ONE year! Never buying Maytag again!!
Oct 22, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Compressor
cant replace it it is a thow away model go to www.apdepot.com do a search for your model you will see here is the Service Manual check your email
May 05, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox Beverage Dispenser Not Cooling
Sears.com is selling skybox parts. Go to appliance and parts and put in the model number of the skybox it is either mbv1976aab or mbv1976aap -- you can find this on the back of the skybox. It might have the part you need.
Apr 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag skybox stopped cooling
I just replaced my in-pieces starter relay and thermal swich with a Whirlpool 4387535 kit. My Skybox has been working fine ever since.
Note I had the same symptoms as other posts of the compressor turning on/off continuously (but no cooling)...I believe what was happening is that the starter relay would allow current to flow to initially start the compressor, but would never stop providing current to it after it had already started (as it should) thus in a few seconds the thermal switch would sense this and trip / remove power to the compressor...then this cycle would start all over once the thermal switch cooled down again and let power back to the compressor...
This kit is evidently the newer style of what is on the original Skybox compressors (functionally speaking)...the new starter relay looks and installs like the old one, but the thermal switch is different and you need to remove the old one (follow the black wire on the top post of the compressor back a little to a small black round thing with a flexible metal piece inside). The good news is that once you remove it, it already has the correct spade lug on the wire to plug directly into the new thermal switch which sits right on the top lug of the compressor above the starter relay.
Note I'm not a service tech, just a Skybox owner who was/is tired of Maytag disowning this product and calling it a "throwaway" when any part of it stops working (and all local authorized service centers laughing when asked to repair one).
Continuing on with my rant a little, I also see other posts on the internet which also state "throwaway" when you actually have a bad compressor because you can't get direct replacements anymore - my friend who does AC work on the side said he most certainly could put another compressor in there from probably just about any other mini-fridge...he just noted that it is a small place to do it so the replacement compressor form factor will have to be considered. He stated you may get a little more or less cooling efficieny but who cares if you really want to keep your machine working that you can't buy anymore (nor get a close alternative).
Mar 13, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
179 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
