I hit some key/keys that made the screen show up in zoom mode. Even when I restarted the laptop, the screen shows up with the large print. How do I get the screen back in normal viewing mode?
  • 4,806 Answers
Just un-install and re-install the graphics drivers, should sort the problem out for you
regards
Posted on Nov 20, 2008
My screen goes blank when I restart, what should I do?
Your screen may be going bad. Try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays your screen that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 29, 2012 | Computers & Internet
Top half of my monitor screen shows at the bottom
Try plugging an external monitor to your laptop and see how it displays on it. It can be any kind of monitor even the old fat crt's as long as it has a vga cable that will connect to your laptops vga port.
If the display does not immediately show up, then you will have to hit the FN (Function key)+(F1 thru F12) to show the image. Press and Hold the FN key then hit the correct F1 thru F12 key. The correct F1 thru F12 key will have either CRT/LCD written on it or it will have a display icon on it.
If the image displays correctly on your external monitor, then you will need to replace your lcd screen.
Mar 25, 2012 | Computers & Internet
Having problems with my laptop theres white lines that goes across my screen and freezes my hole laptop and when i try to turn it on sometimes theres nothing that even show up on the screen
Restart your computer in same mode and see if you see the same issue.
To do this tap the F8 key as soon as the laptop begins to start.
If you see the same problem even in safe mode it might be problem with your laptop screen and might need to be serviced at the service center
Aug 18, 2011 | Computers & Internet
Cannot locate the print scrren key
Print screen is located at the upper right side,in between wifi key and pause key,named "prt sc"
Aug 05, 2011 | Compaq Presario CQ60-220US PC Laptop
Every thing is to large print and screen
Welcome to Fixya.
If the prints on your screen is large, it is possible that it is zoomed in. You can zoom out by pressing down CTRL key then press minus sign (number pad). This will zoom it out. If you want to zoom in again, CTRL key then press plus sign.
Please let me know if this is the fix you are looking for.
Cheers!
Nov 09, 2010 | Computers & Internet
How do I get in safe mode for acer aspire 3690?
You need restart your computer and keep hitting key "F8" while starting up
This will show list of startup available.
Then you need to select "Safe mode" using Up/Down key and hit enter.
This will take you to safe mode.
Nov 05, 2010 | Acer Aspire 3690-2196 Notebook
As soon as I power on My Dell D610 in boot screen appear : '' MANUFACTURING MODE: LEVEL '67''' ''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for...
''PRESS FN + X TO RETURN THE SYSTEM TO NORMAL MODE'. This does not appear to work, it then shows hit F1 for shutdown, nothing happening with that operation either.
Jan 19, 2010 | Dell Latitude D610 Notebook
How do you show the print on the screen b4 u type
Pressing the mode key (L. side of keyboard) the arrow will move on the display you want to leave it on LP.
DickyO
Nov 17, 2009 | Swintec 7040 Typewriter
Laptop dosent log in
Shut down and restart,your computer . At the Dell logo screen, tap on the F8 key slowly a couple of times. Using your up or down arrow key select safe mode and hit enter. Hit enter again. You would see a adminstrator account , login using the same.
1. click start
2. Control panel>user account
3. Change the password of your account and restart your computer.
Thanks for using fixya
proton
Nov 09, 2009 | Dell Latitude D510 Notebook
Browser Enlarged
If part of the web page is not visible on the screen, you may have accidentally dragged it off to the side. Click the green button at the top-left corner of the web page to resize the window to fit on the screen.
If your screen resolution is set to 800 x 600 or less, most web pages won't fit on the screen. If possible, increase resolution to at least 1024 x 768 in System Preferences > Displays.
You may have accidentally hit Command (Apple key) and the plus sign (+) key -- this makes the text bigger. To reduce text size, hit Command and hyphen (-) key.
Finally, if Zoom is turned on in the Universal Access setting, you be looking at only part of the screen -- zoomed in like using a magnifying glass. Hold down Command (Apple key) and ALT key and hyphen (-) to see if this is on -- it will unzoom (zoom out) by one step. Turn this off or on in System Preferences > Universal Access.
I hope that helps.
Nov 18, 2008 | Apple iBook G3 Mac Notebook
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
