Question about Sewing Machines
SInger buttonholer for a 60's slant needle..thread globbing ...
The machine works great, the bottonholer works fine but...occasionally the spool thread globs underneath and can jam up on the bobbin. What might I be doing wrong? I straight sew with the machine successfully but can't do 5 holes in a row without this happening ever so often. I am not sure if I am suppose to have the trailing top or bobbin thread in a certain place? Thanks I have 11 holes to do and have never used this before. Thanks, Laurie
  • lrockman Nov 21, 2008
    Thanks for the great tip. It appears to be a great sewing machine with cool features so that would be excellent for me to do and I'm sure you are right someone there will have a tip for me. Thanks again, laurie
    Problem Solver:
  • 15 Answers
Personally I don't have the experience with a buttonholer attachment, however I do have several slant Singer machines. I'd suggest that you go to yahoo.com and click on Groups. In the search box put in singerslantsewing and join that group. Members are a diverse group of Singer enthusiasts, some repair guys there, and they are happy to assist, should you join and post your problem. There are other groups for Singers, but this group is dedicated to the slant needle models.
Posted on Nov 20, 2008
Which model old style cam type buttonhole attachment from Singer will fit on the Bernina 807 minimatic machine that is an equivalent to the singer featherweight that I can make keyhole buttonholes.
In my earlier response, you need a shank that is made for your Bernina 807 and Berninas made in that era. Only "Old Style" Bernina presser feet and adapters will fit your machine. No other brand will work, not Singer, not Janome, not Brother, nothing but Bernina Old Style. There are several Bernina old style presser feet. Look for presser feet with the number printed in black ink or presser feet that have the number stamped into the metal. Do not buy a Bernina presser foot with red numbers--will fit only newer Bernina machines.
If you want to use the Singer buttonholer attachment, it needs to be for a straight shank machine. You will need to have a Bernina shank adapter for your machine.
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." The first Old Style item is the shank adapter you would need to attach the Singer buttonholer attachment to your machine. (Am assuming it will work, no guarantees!) If it doesn't work, then you will probably not be able to use the Singer buttonholer with your Bernina machine.
This shank adapter would fit your machine:
http://www.ebay.com/itm/Adapter-Low-Shank-Feet-Foot-Bernina-500-1630-Old-Style-/380397208368
If you are looking for a snap-on adapter, it needs to state that it will work with a Bernina Old Style machine, ie the old Record machines (930 Record, 830 Record, 730 Record, 707, 807 Mini, 630 Record, and 530 Record--or in other words, Berninas manufactured prior to probably 1996).
Bernina Presser Feet (down at the bottom of the page, click on the blue text that says "Bernina Shank Adapter" On the next page, scroll down to the last two items that indicate they are "Old Style." If you are looking for the snap-on, go to the very last item on the page (Old Style). This will fit your machine. Remember, if it says Old Style, it should work on your machine.
This snap-on shank will fit your machine:
Presser Foot SNAP ON SHANK Adapter Bernina Old Style 530 532 1630...
This presser foot will fit your machine:
http://www.ebay.com/itm/BERNINA-ORIGINAL-20-SATIN-DECORATIVE-STITCH-FOOT-OLD-STYLE-830-1530-930-etc-/132055492681
This is an entire kit of snap-on feet with shank (included) that will work on your machine:
http://www.ebay.com/itm/20-Feet-Set-for-Bernina-Sewing-Machine-Old-Style-530-1630-Models-/381790565625
Here is a kit of snap-on feet with shank (included) as well as the buttonhole attachment you were asking about:
17 Feet Set for Bernina Sewing Machine Old Style eBay
Although, I believe you will be able to make only straight buttonholes with this buttonhole attachment.
Hope this helps.
Jan 07, 2017 | Singer Sewing Machines
Singer 7462 buttonholer
try adjusting the size, see if it changes the result and go from there, you might also want to ask other experts, sewing machines are not my speciality.
Sep 28, 2008 | Singer 7462 Mechanical Sewing Machine
How to thread on a singer 4411. Thank you
To thread the upper thread, make sure that the needle bar is fully up, using the hand wheel. Put the thread spool on the spool pin and secure it with the spool holder. Use the end of the spool holder that is closest to the spool size. Bring the thread through first guide to the left of the spool holder. Slide it past and behind the guide before pulling it into the guide. Then bring the thread to the pre-tension spring. Similarly, the thread goes behind the spring and then comes forward. Next bring the thread down through the channel and up through the adjacent one further to the left. It helps to hold the thread between the spool and the thread guide. Once you bring the thread up through the second channel bring it from right to left through the slotted eye of the take-up lever. Bring the thread down and through the horizontal thread guide, the thin guide clamp needle and to the needle. Thread the needle from front to back.
The manuals for most Singer sewing machines are available from the manufacturer's site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 4411 is http://www.singerco.com/uploads/download/1230_4411_heavy_duty_esf.pdf . See page page 16 (page 23 of the PDF) for pictures of the guides.
I hope this helps.
Jan 05, 2017 | Singer Sewing Machines
When using buttonhole attachment, machine does not move instead sews in one spot and collects thread coming up from bobbin. Any ideas?
make sure the buttonhole option is chosen
and then pull down the buttonhole lever
it should come down against the buttonhole foot
Apr 25, 2016 | Singer 5400 Sew Mate 60-Stitch Sewing...
I cant get the auto bottonhole attachment to work. I have follow instruction book. Nothing!
Here is a list of YouTube videos showing Singer machines doing Buttonholes:
Google
Mar 08, 2015 | Singer 6423 Sewing Machine
Singer sewingmachine how to stop thread from breaking on the top
Thread breakage is often caused by a burr on the needle. Whenever i have a problem with thread breakage, I unthread the machine, replace the needle, and rethread.
Sometimes thread will wrap around the spool pin, so I use the upright spool pin or use a mug or water glass to hold the spool upright behind the machine.
Jul 19, 2014 | Singer Sewing Machines
Singer quantum XL-150 how do i thread this machine?
All Singer models would have arrows/numbers to guide your top threading from the spool pin to top thread guide, for most machine start from your thread spool pin, to a thread guide follow arrow down then up into the take up lever and down to the needle thread guide then into the needle hole. Assuming you have wind and install the bobbin thread into the bobbin case, turn your hand wheel towards you makes the needle bar goes down,keep on turning till the needle bar is fully up again, pull the end of the top thread to pick out the bobbin/bottom thread. With your material/fabric under the presser feet, apply the presser feet lever down, you are ready to sew.
Dec 24, 2013 | Singer Quantum XL-1000 Computerized Sewing...
My Machine Won't Continuously Sew.
I looked through an online copy of your instruction manual and I don't see a guide which says what that symbol means. To me it means that the upper thread isn't threaded properly. Try one more time to rethread the upper thread but make sure your pressure foot is in the UP position. You may also want to use a piece of unwaxed dental floss and see if you can clean between the tension discs.
I went to Singer for you and found this bit of "help" Perhaps this will help you get back to sewing. It's worth a try.
You may have accidentally lowered the buttonhole lever located just to the left of the needle bar. To make sure it is in the correct position for sewing, place your finger under the lever and push up.
Also make sure the needle is set at the highest position and the bobbin winding spindle has been pushed back to the left or the machine will keep beeping every time you try to sew.
NOTE: To set the needle at the highest position, turn the hand wheel TOWARDS you, until the needle moves to the highest position. Finally, push the reverse button a couple of times, this will reset the machine.
If none of the troubleshooting techniques above solved the issue, please contact a SINGER Service Center to have your machine serviced."
Good luck
Jul 21, 2012 | Singer Sewing Machines
How do you put the thread for the needle for a singer sewing machine model 132q?
Put spool of good quality thread on the spool pin. Thread comes off spool counterclockwise. Raise your presser foot before you do the next steps: Presser foot lifted up now? Great! Pull thread tail from spool toward you and hold thread taut as you put it into first tension disk. Have that thread nice and taut? We shouldn't have any loops hanging down over the machine--okay, Keep threading all of the tension disks. You should be able to actually "feel" the thread fall into slots somewhat. Now when you get to that long silver thing with the hole in the top this is called your thread take-up lever. It should be all the way UP. Turn hand wheel- ( large round knob at end of right-hand side of machine) towards you if need be to raise it. Pull that thread taut from RIGHT to LEFT through the hole in the take-up lever. Take deep breadth here... You're almost done! Pull thread down left side of lever til you get to next disk. Put thread in small bracket located behind needle. Bring thread forward --get yourself 6" of thread-- then put it from front to the back of the eye of the needle. Are you okay? Hope I was able to help. Jimmy
Mar 31, 2012 | Singer Featherweight 132Q Mechanical...
How do I thread the machine
Raise the presser foot.
Place the thread spool on the spool pin so the thread feeds from the back of the spool.
Place spool cap against the thread spool.
Take the thread across to the first guide, then down the first slot, back up the next to catch the uptake lever, then down to the needle.
At the top of the needle there should be a metal "hook" that helps hold the thread close to the needle.
I found a download for the manual at this site for $5.00 - http://www.mastersewusa.com/infos_132Q_Featherweight.html
Apr 02, 2010 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
217 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
