Question about Kirby G4 Bagged Upright Vacuum
Disengaging fan re: Kirby classic III
I have disengaged everything to replace the broken fan. All I need to know is how to dislodge the fan, I'll be ok from there on. Thanks very kindly for any help.
  • 357 Answers
It disengages as i'm vacuming. Very loud. no suction.
If it is very loud, you probably have a broken motor fan. Remove the carpet nozzle from the front and examine the fan for damage.
Aug 16, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How do I replace a belt in my classic iii kirby vacuum cleaner
The below link leads to an excellent video on replacing the belt. It's for a newer model, but I believe they're pretty much the same.
http://www.kirby.com/Portals/0/videos.html
Jan 15, 2011 | Kirby G4 Bagged Upright Vacuum
Can you give me a list of Kirby vacs models & the year they were released so that I know how old they are?
1935 KIRBY Model R*
19?? KIRBY Model 2R
19?? KIRBY Model 3R
19?? KIRBY Model 4R
19?? KIRBY Model C
1939 KIRBY Model 2C
19?? KIRBY Model 3C
19?? KIRBY Model 4C
Model 505 - 1945
Model 508 - 1948
Model 509 - 1949
Model 510 - 1950
Model 511 - 1951
Model 512 - 1952
Model 513 - 1953
Model 514 - 1954
Model 515 - 1955
Model 516 - 1956
Model 517 - 1957
Model 518 - 1958
Model 519 – 1959
Model 560 - 1960
Model 561 - 1961
Model 562 - 1962
1963/64 Sanitronic VII (Sirocco)
1965-67 Dual Sanitronic 50 (Sirocco)
1967-70 Dual Sanitronic 80 (Avocado green)
1970-73 Classic 1CR (Medium brown, gold bag)
1973-76 Classic Omega 1CB (Dark brown, dark brown pinstriped bag)
1976-79 Classic III 2CB (Candy-apple red, plaid bag)
1979-81 Tradition (Dark blue; intro of paper bag)
1981-84 Heritage (Gray/orange)
1984-89 Heritage II Legend (Charcoal/gray/red)
1989-90 Legend II (Dark rose-pink)
1990-93 Generation 3 (Alabaster)
1993-96 Generation 4 (Medium gray)
1996-99 Generation 5 (Maroon)
1999-01 Generation 6 (Black/Yellow)
2002-05 Kirby Ultimate G
2005-06 Kirby Ultimate G Diamond
http://www.vacuumwizard.com/history-of-kirby-vacuum-cleaners.html
Sep 12, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 rear wheels lock up completely when in "Drive"
When wheels lock when vacuum is OFF - it is normal. If it happens when Kirby is ON then there are a few things that may have gone wrong
Primary drive belt is broken or something is wrong with plastic gears. See how to check the primary drive belt HERE.
If it is fine and gears are spinning - then something must be wrong inside the transmission. Parts for tech drive are not available from manufacturer so you are on your own. It is not really complicated - 2 clutches that engage and disengage depending which direction you push the vacuum. But if something in there is broken - you have to get a new tranny. It is not like getting a transmission for a truck but it still will set you back by about 100 $.
Good Luck
Rocky
May 16, 2009 | Kirby G5 Bagged Upright Vacuum
I NEED A MANUAL FOR A KIRBY CLASSIC III 2-CB. ANYONE? THANKS.
If you go to http://www.vaccc.com/OWNERS_MANUALS.htm and scroll down to kirby classic III, the manual is listed that you can look at or print for a 1976 model. Hope this will help you out.
Mar 24, 2009 | Kirby Heritage II Vacuum
Transmission not engaging
In Kirby vacuums with tech drive there is a part called Bracket cam (see it here) that is designed to disengage wheels from transmission. When it starts wearing out Kirby would make crackling noise when on neutral and eventually may not disengage at all. If there was no stage where it was noisy on neutral it may be something else - most likely the pedal assembly broken (see it here). It is not very hard to replace it.
Oct 26, 2008 | Kirby G4 Bagged Upright Vacuum
REPLACING BELT KIRBY CLASSIC III
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=806061
Posted by JETALBOT on July 19, 2008
I CAN'T REPLACE THE BELT ON THE CLASSIC III (KIRBY). CAN YOU HELP ME? ELAINE
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 19, 2008 | Kirby Heritage II Vacuum
Front switch broken on Kirby Classic III where I can buy it in Toronto, Canada area
Generic problem for all Vacuums
You can contact a local dealer that can be found in the yellow pages under vacuum or you can call the Kirby factory to see if they have a local dealer or can send out the part to you from the factory. I will give some examples listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.AVACcorp.com 1-800-328-9430 they can ship out the part if you need it and if you cannot find it anywhere else.
Apr 18, 2008 | Vacuums
Kirby G4 Bagged Upright Vacuum Logo
172 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
