Question about Samsung 226BW Monitor
Samsung 226bw weird display problems
Everything was fine with my pc,then one day i turn it on and my monitor powers on but no display.Only the analog and digital display is on for a few seconds then the monitor turns off.The power button light is blinking,like its on standby.I then unplug everything,plug everything back and turn it back on.This time the monitor comes on,but the bios looks weird,there are jumpled up letters all other the monitor.Once windows comes on there are small blue jagged lines all over the screen.I have no idea what could be the problem,everything else seems to be working fine.I'm guessing its either the monitor or my graphics card,which is a gtx8800.Any help would be greatly appreciated.
At first you should clarify if your GPU or LCD is broken.
Do You have any chance to try another monitor with your Graphicadapter or to try your monitor on a different PC?
Moreover you should try it with a new cable.
The symptom of weird symbols sounds most likely like a overheated or wrong-plugged Graphicadapter
Posted on Dec 12, 2008
The monitor either stays blank when the pc boots up or displays briefly and then goes blank. It will sometimes display properly if I turn it off and on after the computer is fully booted up. It has been...
First place to look will in the power supply section, look for bad caps with bulging top/bottom seal, post back what you see inside so we can help you further, see example of failed SAMSUNG monitors due to bad caps here:
Jan 27, 2010 | Samsung 226BW Monitor
My 3 yr old Samsung 226bw strobes when switched on
colinfaver, I think a visit to YOUTUBE and conduct a search for longer vid clips of "lcd monitor disassembly" and "lcd monitor repair" for monitors that suffer from the "black screen of death" syndrome and what internal electronic components fail and how to visually locate them on a "switch-mode-power-supply" and possibly replace them with new good ones and with a little luck end up with a working monitor. Your 226BW is SICK, and will probably do same if connected to a different PC with same ambient room temperature. Yes, problem with SMPS/CCFL inverter supply getting a bit tired!! If this was of help to you, please rate on fixya, and do return comment. 12fixlouie Bye for now.
Nov 17, 2009 | Samsung 226BW Monitor
Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Corporate Computer
Jun 17, 2009 | Samsung 226BW Monitor
1of 2 monitors wont turn on
Frostbane is correct. I called 1-800-SAMSUNG to report the same problem and they are going to send me a replacement display.
Mar 24, 2009 | Samsung 226BW Monitor
Power on but display cuts out
Sounds like the backlight's gone. You can try to open up the case and replace it, but an easier (and probably cheaper) option is to simply buy a new monitor
Feb 13, 2009 | Samsung 226BW Monitor
Samsung 226BW won't turn on until a few minutes.
This is an indication that the power board in the monitor is bad.
Mar 02, 2017 | Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
Movie on monitor
Hi, Normally I would suggest that you first lower your laptop's screen resolution, refresh rate and color quality and verify that you have enabled the external monitor or dual view in your Display Property Settings as well as the Fn key + F?. However, this kind of problem should not exist with an LCD Widescreen monitor with specs and features as your Samsung 226BW. If trying the reco on the first paragraph and you still have no movie display (but all other laptop display shows), perhaps it is a problem with the Samsung 226BW. To my knowledge, this particular brand/model uses no less than 3 different panel display, some not as good as the others. Verify that you have an original Samsung panel display in your Samsung monitor by looking at the sticker at the back of the screen, it should say Model: 226BW [R] S. If it says A or even a C, then perhaps the display panel is not living to its specs/claimed capacities. You of course can request a replacement from your dealer and cite your problem but insist that it be an "S". Most instances (but not always) an "S" would mean panel screen by Samsung, "A" by AU Optronics and "C" by CMO. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | Samsung 226BW Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
342 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
