Question about Whirlpool 10 cu. ft. Chest Freezer EH101FXR
EH101FXR I just got the whirlpool 10ft freezer eh101fxr. My question is that on the rear backside where motor is there is no cover- is that normal? My plder freezer is covered on all sides with some vents- this new one you can see the motor and wires
  • 367 Answers
The cover being gone will not hurt anything. It may be missing but its ok. Some dont even come with the unit anymore. its all ok.
Posted on Nov 20, 2008
I have whirpool chest freezer defrosted and off for 4 months then turned on 2 red lights going motor is running but not freezing turned up temp to coldest tempurature with amber light on stil the motor...
Since the motor is running, the compressor it is connected to must also be running. The compressor is the thing that provides the cooling under normal circumstances. The only thing I can think of as to why you are not getting cooling is that the refrigerant charge has leaked out of the system. I don't know anything about the red lights you mention.
Aug 25, 2014 | Whirlpool 10 cu. ft. / 283 liter Chest...
I need the owners manual for the estate chest freezer model no. tcf1510ew00, or if someone could just tell me the temp settings for each number? it shows on the side that 4 is i guess the freezing point...
The numbers are generic and don't mean a thing. They are there to make you feel like you have control. Anything under 1 should be very much frozen. If it is not then you have T-stat problem and should address that. Chest freezers run at -25f on average if the freezer has enough product in it. The more food in the freezer the better and more efficiently it will run.
Apr 10, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
Motor or compressor keeps clicking on and off and will not get cold and the inside light dims when this happens
I would suggest the compressor and or motor are failing. The reason the interior light is dimming when the relay connects the compressor is a larger than normal demand on the power supply, i.e drawing more current (amps) than it was designed to.
Jan 06, 2014 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
The outside coverings feels hot and water leaks from the unit, what causes this problem?
If by coverings you mean the side of the cabinet, that is usually an indication that the compressor is running hotter than normal, could be a bad compressor, compressor fan, a leak of refrigerant, a dirty condenser coil or some other problem possibly. check to see if the fan is running, and if the condenser is dust clogged.
Oct 05, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Whirlpool fridge working but not staying cold
Check the freezer for ice build-up. You will need to remove the rear and bottom covers for this. Frequently, ice will build up in the passageway between the refrigerator and freezer and/or in the defrost drain. If you remove this ice, your refrigerator will resume normal operation.
Feb 02, 2010 | Freezers
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
I have a whirlpool freezer, the red light on the front is on and the food appears to be not fully frozen. I have turned the temp dial up a bit but the light stays on? I can't find the book that came with...
The light is there to indicate there is power. If it is running constantly and still not cooling properly there is a problem in the sealed system (or the door is not sealed completely, but there would be a lot of frost were this the case. Here is a link to where you can find the manual with a complete model number.
HDR-SR12E Eric
Jul 02, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Whirlpool 10 cu. ft. Chest Freezer EH101FXR Logo
120 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
