Question about GE WWSE5200B Top Load Washer
Agitator on ge washer pops up and then won't agitate.
On our old GE Washer (which works great otherwise!) the plasticagitator pops up and then doesn't agitate. In otherwords, I can easilypull the plastic agitator right up off of the metal "rod" that actuallyturns it - and remove it from the washing machine very easily when it has popped up on it's own. I see that there is a rubbery looking collar that fits of thetop of the "rod" that apparantly keeps the plastic agitator on snugglyunder normal circumstances. So I think that when this pops up theplastic agitator isn't turning because it isn't gripping the "rod"? When it gets to this point sometimes I am successful at jamming it back into place and then it works for a little while but sometimes doesn't make it through 1 cycle. So, how do I fix it? Does it need a new rubbery collar thingy and if itdoes, what would I ask for. Or is the problem greater than that. Ican't see any other mechanism that would hold that agitator in placeother than the rubbery collar that looks like it is about a 4" long grippy type tupe that fits over the upper neck of the "metal rod". I LOVE thiswasher! I don't want it to die!!! HELP!!!
  • glentanner Dec 12, 2008
    Will not agitate. agitator is popped up.
  • 1214 Answers
SOURCE: GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Posted on Jan 26, 2009
  • 4 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
Posted on May 30, 2009
  • 111 Answers
SOURCE: GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Posted on Jul 15, 2009
  • 35 Answers
SOURCE: Knocking noise during agitation cycle - GE WNSR2100T8WW
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating) However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits. Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
Posted on Sep 17, 2009
  • 464 Answers
SOURCE: GE WDSR2080D4WW top load washer agitator - Is
pull out the agitator. this may be difficult because soap gets built up underneath and250 acts almost like a glue. use a leather belt and put it under the agitator and pull straight up. once you get it off you will see a bolt holding down a coupling. take the bolt out and replace the coupling with a new one. this should solve your problem with the machine not agitating. the part # for the bell coupling is: WH43X10009.
Posted on Oct 24, 2009
Testimonial: "thanks! we'll get back with you on if this works or not!"
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Washer squeaks really loud while agitating. Drains great 6yr old
Could indeed be the belt or at worst it could be thr main bearing getting dry and gradually seizing up. Hope it,s the belt!!
May 20, 2009 | Washing Machines
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
Mar 04, 2009 | GE WBSR3140DW Top Load Washer
Agitation problem
You probably have a problem with the agitator dogs. Located inside the agitator are agitator dogs. They are little plastic looking teeth that have smaller teeth on them. The sit inside the agitator and grab onto the teeth in the agitator stopping it so it agitates. If you pop off the top of the agitator and look in you will see them in there. They are small and off white. Cheap parts running around 7 dollars for the pack of four. Easy to replace too, just remove the old and replace with the new. Let me know if you have any other questions and if this was helpful. Good luck and have a great weekend.
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
GE washer not agitating
when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
Dec 11, 2008 | Washing Machines
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Dec 03, 2008 | GE WBSR3140DW Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
GE WWSE5200B Top Load Washer Logo
76 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
