Question about Microwave Ovens
Emerson microwave turn table does not turn
This microwave is just out of warranty. However it has been used approximately a dozen times. It is at our cabin. To have it fixed according to the manufacturer is more than we paid for it at Target. Any suggestions
  • Microwave Ovens Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Posted on Nov 21, 2008
My emerson 899rd dosnt heat up food
It's probably a failed magnetron or loose connection at the "FA" terminal of the magnetron.
Nov 27, 2012 | Emerson Mw8999rd Microwave Oven
When I press the start the button the turn table inside microwave is not turning and there is not heat on the food. But the light is on and the clock is working. What do you think is the problem? and what...
The turn table motor of your microwave is defective already and also the magnetron - the source of generated heat of the microwave is also defective. But before assuming that magnetron is dead, check the high voltage fuse it may be blown and replace the fuse (if it is blown) it with similar rating. I hope I help you with your microwave problem.
Mar 21, 2011 | Emerson MW8107WA Microwave Oven
Turn table stopped working on my emerson microwave
The Turntable motor is defective and will need to be replaced, you can contact the manufacture for the part, or call in a appliance repairman to fix the problem.
Jan 26, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
We have a emmerson micro and the turn table cluncks
Problem fixed. Called number on micro and they were great in fixing the problem.
Oct 28, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
My emerson mw8117w just stopped working
hi! first thing first check all the fuses for busted.
Sep 15, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Hi I have an Emerson microwave oven MW8998B. The turn table will not rotate while cooking. The smaller bags of popcorn just burn the bag. Does this need a repairman or can I fix it myself. Also, I am able...
Hi, I had the same problem with my Emerson microwave. As I rent out the house, and the turntable stopped working while I was away, my rental agent bought another Emerson microwave. On my return I tried using the new (brown) plastic turntable on the old microwave, and found it worked perfectly. Maybe it would be possible for you to order a replacement turntable part. Hope this helps. Good luck, Rosalind
May 13, 2009 | Emerson Black Microwave Oven
Microwave not turning on
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If you still have trouble, since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Aug 09, 2008 | Emerson MW8107WA Microwave Oven
Emerson Microwave MW8115SS
I bought my emerson microwave 3 years ago model# mw8115ss from walmart and have had all the problems that everyone has talked about and I thought about throwing it away until I thought about one small detail, the FUSE. China uses junky glass fuses that burst instantly with a slight power outage, door slamming to hard, moving it around, and of course constant use like myself always heating up water for bottles. I took the back of the microwave off and walla!!! a blown fuse, but wait!!! dont buy another glass fuse!!! go to your local home depot and get the ceramic fuse for microwave ovens!!! they are $2.83 at my local home depot. I replaced the junky glass fuse with the ceramic one and it has worked perfectly for six months now.
DONT let someone tell you that you cant replace a glass fuse with a ceramic one because they are full of boloney. My microwave did all kinds of things, it wouldnt turn sometimes, it would come on by itself, it would beep for no reason, turn but not heat up, you name it I had the problem. When a fuse starts to go out it can make your appliances do some strange things, check the fuse and replace it with a CERAMIC one and I promise it should eliminate your problem.
Apr 22, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Need a turn table
It depece on where you live?? Go online and type in Emmerson MW8108 microwave. I got lots of links. Good Luck
Jul 12, 2006 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
