Question about Kenwood ProTalk UBZ-LF14 (14 Channels) 2-Way Radio
RECHARGEABLE BATTERY IS NOT HOLDING A RECHARGE
I charged both of my transceivers and one doesn't seem to hold a charge. Where can I get this repaired or replaced?
    New Friend:
  • 109 Answers
This sounds like you have a battery that has gone bad. If this is the case then it is possible that your local dealership can sell you a new battery. If they can't then try searching for the battery number on ebay or another website that sells batteries.
Patrick
Posted on Nov 21, 2008
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Why is my nikon coolpix L20 battery exhausted even with new batteries
If you are using rechargeable batteries, It could be that your camera's battery charger circuit is defective. If your camera is out of warranty, the cheap solution would be to buy an external charger. Another possibility is that a short circuit or defective electronic component is drawing excessive current and draining your batteries. If that is the case, you will need to have your camera repaired. Nikon USA Repair Depot's number is 1-800-645-6687 9AM-8PM EST, Monday to Friday. They will tell you how to return your camera for repair and they will give you a free estimate if it is out of warranty.
Sep 01, 2014 | Nikon COOLPIX L20 Digital Camera
My zpad won't hold a charge
Lithium ION batteries are useusally rechargeable. The use mode for these batteries is that there
are a set number of recharges that equate to the life of the battery. Usually that life is
approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the
battery is used up, the maximum charge lessens which means where you may have had 8
hours of play time when the battery was new, you will only have 6 hours as the battery life is
used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge
left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never
recharge again or the max charge will be reduced to an insignificant amount of the original full
charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries
cannot have their batteries replaced.
Jun 05, 2014 | Tablets & eReaders
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
My Coby 4GB Touchscreen Video MP3 Player (MP828) is not holding charge for a long time ... what should i do ?
Rechargeable mobile devices can lose their ability to hold charge if they aren't charged properly. The best way to charge your device is to let the battery die all the way before recharging it. Overtime, when you repeatedly recharge your batter without doing so, it loses it's function. In addition, try keeping your brightness on low.
May 05, 2011 | Coby Audio Players & Recorders
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
12v drill/driver not holding charge
sounds like the batt as had its the same prob as i had with mine to give it a bit of life so it will charge get hold of a bigger batt and two bits of wire and connect the + to + and - to - and it should charge but it prob will run down quick
Mar 15, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
New Haier 7.2V rechargeable NI-MH battery pack for a new Haier Portable DVD player was stored in a drawer for 2 years until recently. Attemped to recharge battery pack via electrical outlet. Obtained...
the battery pack is charging but not holding charge beacause it was not used for a long time as you said.try to recharge and completely drain the batteries a couple of times and the batteries should start holding better the charge.Another thing you may want to check is if there is power coming out at teh battery pack connectors(you will need a small volt meter)
Oct 02, 2008 | Televison & Video
Radio Communications Logo
96 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
