Question about Memorex MLT2022 20 in. EDTV-Ready LCD Television
My Memorex LCD tv model #MLT2022 will not work as monitor
When I hook up the unit to my PC and turn both on I see the Windows XP start up and them the screen goes black and "not supported" shows. How do I get it to function properly?
  • 362 Answers
SOURCE: Can not access menu or input functions
Hi rduncan27,
I will be happy to help. 88% of LCD tv problems are with the backlight, the symptoms you described indicate a probable inverter malfunction. Lets do a simple test to check the functionality.
  1. Get the tv to a point that it is producing sound.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely for a dark video image.
Let me know your findings and we can proceed from there.
Lone99star
Posted on Jan 26, 2009
budmrtn
  • 11361 Answers
SOURCE: the tv briefly powers up shows the memorex logo
The poroblem can either be the 12~18vdc power supply section is not supplying the power to the backlight inverter board or the inverter board went out, you need to check voltage on the power supply, also look to see if you see any caps with leaking/bulging top.
See example of failed TV and monitors here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
budmrtn
  • 11361 Answers
SOURCE: Memorex mlt3221. white screen, no sound, no function.
Check the power supply module for bad DC filter caps first, then check the backlight inverter board for shorts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Posted on Jul 29, 2010
freetek
  • 5568 Answers
SOURCE: I turned on my tv
LCD sets (other than those very new) use fluorescent back lighting to produce the picture. Those lights require high voltage to ionize them so the problem could be either the tubes themselves or the inverter that produces the high voltage is failing. Anyone with some degree of manual finesse and possessed of logic can cure this problem but it may be difficult to identify the failed part accurately meaning that if you 'shotgun' the problem, you would need to replace both the tube(s) and the inverter board. The latter is in most sets as a separate assembly which derives its operating voltage from the main power supply and will be obviously attached to the fluorescent tube(s).
The board will have to found from the manufacturer or a company that disassembles scrapped sets.
Check with the site below for availability:
Jimmy's Parts
Search on your set's model number and the term 'inverter.'
The tube(s) can be bought from several US suppliers.
Posted on Oct 17, 2010
SOURCE: No picture on Memorex MLTD3222 flat panel LCD.
I am having the same problem... never happened before and I've had the TV for about 2 years. I tried unplugging it for about an hour and plugging back in, but not working. Will try it overnight and see what happens.... *sigh*
Posted on Nov 15, 2010
I HAVE BEEN GIVEN A LT 456s MONITOR AND AM TRYING TO HOOK UP TO A GATEWAY COMPUTOR WITH WINDOWS XP- WHEN I TURN IT ON THE GATEWAY WINDOW SHOWS UP AND THE THE WINDOWS XP AFTER THAT IT IS BLANK UNTIL A NO...
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mar 10, 2011 | Mag Innovision lt456s 14" Flat Panel LCD...
Need a new power cord. Existing one dose not supply power to turn on tv
i think you already have an answer of your problem..at the same time, check first the AC LINE before checking the power supply section...
Aug 25, 2010 | Memorex MLT2022 20 in. EDTV-Ready LCD...
The power supply light keeps blinking green and the tv wont come on
Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 14, 2010 | Memorex MLT2022 20 in. EDTV-Ready LCD...
COMPUTER WON'T WORK WITH NEW HD LCD TV
Sounds like the PC has too high a screen resolution set for the TV to handle
Re-connect PC to PC monitor , change display resolution to 800 x 600 (right click desktop, properties, settings, slider marked "screen resolution" to leftmost side, save settings.
connect PC to TV, TV should be able to display PC data now.
Go through same procedure with PC connected to TV, move slider to 1024 x 768 posn. (depends on TV model as to what it can cope with) - *apply* this setting & see if TV is able to display at this resolution.
If it is, desktop will appear - if not, you'll get the warning box generated by the TV...don't worry, in 15 secs, the PC will revert to the old (working) setting.
Hope this helps.
Dec 19, 2008 | Computers & Internet
Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Acer X193W LCD Monitor
Dell Inspiron 100
I hooked it up to the monitor on my desktop and it worked sooooooo I need a new laptop monitor---I guess
Aug 24, 2008 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
No picture and no sound
I have the same TV. and same problem. I changed the power supply with a similar one that has the same plug. the TV came back to life. voila.
Oct 09, 2007 | Memorex MLT2022 20 in. EDTV-Ready LCD...
19 inch portable TV Memorex
Hi! I realize that you posed a couple years ago, but I am having the same problem with my relatively new Memorex MLT 3221 model. How did you solve it??? I have tried every 'layman' solution that I can think of! Please help!
Dec 31, 2006 | Memorex MLT2022 20 in. EDTV-Ready LCD...
Memorex MLT2022 20 in. EDTV-Ready LCD Television Logo
50 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
