Question about Whirlpool RBD305PD Electric Double Oven
Zanussi Zuf270x Grill element
Hi, just wondered if you could advise me on the change of a grill element for this type of dual grill element, i have a new element on order but i am unsure how this is fixed into the top grill, any information would be greatly appreciated
Many thanks
P.S would this involve me taking the oven out or could i do this from the front??
catriver
  • 878 Answers
SOURCE: Single oven not heating
diydoris, you would have to have someone ohm out the lower element to make sure it is good. If the element is good, then your problem probably is in the TCO. This is a thermostat that sits on the back of the oven that can go bad. You can test this with a meter, if it shows open (no continuity) its bad. Part number for the TC0 is 4450934. Part number for the element is 4448696. Catriver...post back.
Posted on Sep 28, 2006
barkencoa
  • 3463 Answers
SOURCE: Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
Posted on Dec 12, 2008
PSITECHNICAL
  • 71 Answers
SOURCE: Oven Not Heating Up
the control panel, has a relay that controls the heating in the oven, it's not closing ther circuit. the electronic timer/control panel, has to be replaced
Posted on Apr 21, 2009
heavyice
  • 374 Answers
SOURCE: I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Posted on Jun 04, 2009
protek480
  • 1714 Answers
SOURCE: Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Posted on Sep 01, 2009
Im re[placing grill element and when i removed element a probe which runs abve element is hanging. what is this for and how does it fix and where
On my Zanussi Grill element there is a clip on very slim "bracket" which has a place for the Thermometer tube to clip in. The bracket is right where the terminals go through the rear of the oven. Does this help?
Jan 27, 2016 | Zanussi Ovens
Using grill and everything tripped now grill or oven wont work
Electric grill most often uses heater element to heat up.Maybe your heater elemen is shorted to oven body thus tripping the safety device.
Check your grill system using insulation tester.If the insulation is low check the heater elemen insulation and if defective replace them.
Jun 17, 2012 | Zanussi ZBF360 Electric Single Oven
Grill not working after replacement element - any ideas?
I would say you are right on your wondering. look at your manuel and it will show you a diagram
May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
The grill on Zanussi FM9232 keeps blowing the main fuse
the grill element needs replaceing or you have a wire on the grill element thats come off and touching down to earth
Sep 07, 2011 | Zanussi ZHQ575 Electric Double Oven
My grill on my cooker keeps going off and on... you cant grill cheese on toast as the grill goes off and the cheese goes cold?
We know that the grill element is working because it does get hot. It sounds like a problem with the grill control.
Feb 11, 2011 | Zanussi Ovens
My grill doesnt seem to be working,the oven seems to be ok making all the noise and stuff but the grills just not playing ball! nany help would be appreciated!
More than likely the grill element has failed, if the element light comes on, then I would go for the element.
If no light, then probably the grill switch is faulty.
Nov 14, 2010 | Zanussi ZBF360 Electric Single Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Grill not working
Yes, you will need to replace the whole element.
Dec 07, 2008 | Zanussi ZHQ575 Electric Double Oven
Grill not heating up properly on my zanussi oven
Hi.
Sounds like you have only got half the element working. some ovens have 2 seperate elenents forming the grill. Check if this the case.
Nov 19, 2008 | Zanussi ZBQ665 Electric Single Oven
Whirlpool RBD305PD Electric Double Oven Logo
57 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
