We experienced a power surge at our home. Our tv screen will no longer come on. Is there something we can do? A repair person is to expensive and I would like to try to fix it. THE MODEL # LTV-32w6HD; Type# SLT32D.Is there a wiring diagram or something available so that I might try and track the problem down.myself
  • 33 Answers
There are 2 fuses located on the inside of the tv you can check, usally they are white. mie has one on the far right board and one on the middle board.
also check out this website you might find you or a similar TV chassis # service manual,
GOOD Luck...
Posted on Nov 20, 2008
My Sony KDL-46V3000 television HDMI ports no longer worked following a thunderstorm, and a factory/power reset did not fix the problem. Do you know what board I need to replace (GF1,DF2,DF3)?
A nearby electrical storm can cause a voltage surge in the mains electrical supply or a very close storm could send a discharge along the antenna downlead and either way the ultra-sensitive CMOS logic chips are likely to be damaged. Such chips are likely to be found throughout a modern tv.
These days a tv is less a television and more computer and should always be used with a surge protector though these cannot provide full protection.
I suggest you entrust diagnosis to an experienced engineer in order to reduce the frustration and expense to a minimum.
Jul 12, 2017 | Sony Televison & Video
I've just experienced 2 separate TVs ( a Motorola and a Phillips) installed in...
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem on dvd with no receiver box connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
on Dec 24, 2009 | Toshiba 61H71 61" Rear Projection...
Stopped working after a storm
Did you have a power surge after a loss of power? If so your TV is ruined from the surge. In the future use a surge protector if don't already.
Aug 20, 2016 | Televison & Video
First the screen picture started to flash between the picture and a blacked out screen, then it just completely turned black along with thin lines across the screen horizonally. I checked all the...
I'd Guess it'd be something with the lightning or you have to wait for a while for the entire screen to pop up while its turned on thats what happens to my grandma.
Oct 29, 2013 | Sceptre 32" 1080p LCD HDTV X328BV-FHD
Had a power surge into the house- the tv was not on a surge protector and i am wondering if the tv is blown out- or is there a fuse possibly that blows at a power surge?
hello kath... if the tv won't come on now the power surge fried internal fuse and possibly more. The least expensive way to get this repair is to physically take the tv to the repair shop. If they have to make house calls, the cost goes up significantly. Joe
Apr 21, 2011 | RCA HD52W59 HDTV Projection Television
After a storm my tv nolonger turns on but the on
The TV has been spiked by a power surge. You could try to unplug it for several hours to see if it will reset. If this does not fix it then the problem is major, requring a new power board and possibly both sustain boards needing to be replaced. This is also very expensive about $600. If you have home insurance make a claim for FUSION. At least the parts will be paid for
Get the servbice person to actually write fusion damage on the receipt
Please rate my help++++Thanks for using FIXYA
Jun 12, 2010 | JVC AV-30W475 30" TV
No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Jul 15, 2009 | Samsung LE32A457 32 in. LCD TV
DENON AVR 2308 no longer works only after 3 weeks of purchase!!!
You need to get more details. What component has failed that makes them believe that a surge caused the problem. There is usually a thermal fuse inside of the main power transformer that CAN be effected by power surges. WIthout more details, I really can't rpovide any ammunition for your claim. Please request exact details from the servicer.
Mar 05, 2009 | Denon AVR-2308CI
Flashing screen
The power compensator IC is bad along with most likley the main board. This is going to be an expensive repair. If the warranty expired in January, and you were in touch with them about then and they did nothing, you should try to fight with them. They may send out a repair person to get your set working again. Another possibility would be, if you have homew owners insurance and a tech can say that the problem was due to a power surge, the insurance will take care of part of the repair bill. Good Luck
Mar 23, 2007 | Samsung TXR3079 TV
Enlarged picture
First thing to dois unplug the set for a GOOD 24 hurs
Sep 14, 2006 | Zenith A36B41W 36" TV
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
